Why adventure riders are taking notice of Leatt motorcycle gear in 2026
Despite a rich heritage in producing motorcycle apparel, honed and perfected over 20 years of developing gear for motocross and enduro riders, it was only in recent years that South African brand Leatt made the move into adventure biking.
In this relatively short time, it has established itself as not only a gear manufacturer to be reckoned with, but one to be relied upon.
Through its well designed and robustly constructed range of kit and equipment, Leatt has earned the right to be taken seriously as an adventure contender, with products regularly ranking alongside, and often exceeding, more established names in ABR tests and reviews.
So, with plenty of gear released by the brand of late, we thought we’d take a closer look at some of the highlights currently found in Leatt’s line-up made specifically for adventure bikers.
ADV 7.5 Helmet with 2.5 Goggle
£289
Leatt ADV 7.5 Helmet
Adventure biking gear can be tough to get right. It needs to be capable of covering distances on-road in comfort, but also offer the functionality required for off-road trail thrashing. This requirement for dual-purpose performance is thrown into particularly sharp relief when it comes to helmets. How can a lid work on both the A1 to Wetherby Services and the remotest corners of the Trans Euro Trail?
Leatt’s ADV 7.5 helmet might provide some answers. It has been designed specifically for mixed riding, with different set-ups for road, trail, or off-road use, meaning there’s no need to change helmets when you change terrain.
How you choose to configure the helmet is up to you, but the versatility of the ADV 7.5 is undeniable. Remove the peak and you’ve got a road lid. When the tarmac becomes more trail, put the peak on to enjoy the sun-shielding and high-speed comfort of an adventure lid. And for technical off-road rides, take advantage of the extra-wide eye port and switch out the Pinlock-ready visor (the twist of a clip is all it takes) for the included Leatt 2.5 goggles.
The inside of the helmet is also tuned for rider comfort and protection. Adjustable ventilation offers a cooling through-flow of air on long, hot days, while an antimicrobial liner and washable cheek pads help keep the helmet fresh ride after ride.
Inside, you’ll also find Leatt’s 360-degree Turbine Technology. This has been developed to reduce impact forces and rotational acceleration, helping to reduce the risk of injuries in the event of an unexpected clash of your head and a hard surface. The ADV 7.5 is also comms-compatible, features emergency quick-release cheek pads, and carries the latest ECE 22.06 and DOT certification, ensuring it’s ready and able for real-world adventure riding.
ADV DriTour 5.5 Jacket and Pant
£479 (jacket) £369 (pant)
Leatt 5.5 DriTour Jacket and Pant
Although the versatility of gear featuring multiple layers is an attractive proposition in mixed weather, jackets and trousers that are inherently waterproof without the need to add layers have their advantages too.
In the ADV DriTour 5.5 jacket and trousers, Leatt’s HydraDri EVO membrane is laminated onto the main fabric, making it waterproof without the need for a separate rain shell or liner. This makes changeable weather a doddle. There’s no need to pull over to adjust layers as soon as it starts raining. Plus, because there’s no separate internal liner to reduce breathability and block vents, opening the DriTour 5.5’s ventilation zips creates an unrestricted airflow for cooling off when the sun comes back out.
Leatt may have built its reputation in motocross gear, but the ADV DriTour 5.5 has been specifically built for adventure riders. The pants are designed to fit comfortably over chunky adventure boots, there are leather panels on the inside of the knees for grip and control, and both the jacket and pants offer plenty of practical storage, including waterproof and quick access pockets. Plus, both the jacket and trousers have been tailored to the typical adventure riding position.
Riding comfort is further aided by stretch zones for free movement, multiple adjustment points to perfect the fit, and a solid jacket-to-pant connection zip that helps the whole suit move with the rider.
And, of course, the ADV DriTour 5.5 jacket and trousers are chock full of protection. Both are EN 17092 CE AA rated, with Leatt’s soft, flexible, and ventilated 3DF armour in the elbows, shoulders, back, knees and hips. All of it is CE-level 2 rated, and there are pockets for optional chest armour in the jacket.
ADV MultiTour 8.5 Jacket
£719
Leatt 8.5 Multitour Jacket
When Leatt first stepped onto the adventure scene, the MultiTour 7.5 jacket sat at the top of its range. It remains a superb jacket, offering a do-it-all solution for the most demanding on and off-road adventures in all weathers. But somewhere along the line, Leatt has taken a long hard look at the MultiTour 7.5 and wondered if they could perhaps do even better.
Like its sibling, the ADV MultiTour 8.5 can be switched between waterproof, windproof, insulated, and fully vented set-ups, adapting to changeable weather conditions and negating the need to pack multiple jackets.
A waterproof over shell covers the ventilated top half of the jacket, which can be zipped in and out. This combines with a laminated lower half to provide reliable rain protection. A removable thermal liner boosts heat retention on cold rides without adding bulk and can be worn as a casual jacket off the bike, even offering a little protection from light rain.
And with the waterproof and thermal layers removed, the fully vented upper half of the MultiTour 8.5 keeps airflow high in hot weather, giving the feel of a mesh summer jacket. From fending off downpours in the Welsh valleys, to keeping out the chill crossing Alpine passes, and coping with heat on sunbaked desert trails, the ADV MultiTour 8.5 is designed to be one jacket to rule them all, a bit like a good adventure bike.
In addition to its versatility, the MultiTour 8.5 also provides essential protection, and lots of it. The jacket carries an EN17092 standard CE AA rating which makes it rated for high-speed touring. And the supplied armour, which includes elbow, shoulder, back, and chest protection, is all the CE-level 2 certified. For riders tackling particularly gnarly off-road routes, the jacket is also neck brace compatible.
So, if you consider all of the above, add in plenty of storage (including waterproof pockets and a pouch for a hydration bladder), loads of fit adjustment, and Leatt’s five-year warranty, the ADV MultiTour 8.5 shapes up to be a great riding companion for full days over thousands of miles in any weather.
Leatt ADV HydraDri 8.5 Boots
£419
Combining the tough build of off-road boots with the comfort of adventure boots, the ADV HydraDri 8.5 has been built for a specific rider: off-road-oriented, not hyper-aggressive, who rides far. And it’s been developed to cope with the kinds of real-world scenarios these riders will actually find themselves in.
Cold mornings and wet weather? Leatt’s HydraDri EVO membrane offers reliable waterproofing and weather protection. It’s breathable, too, so your feet shouldn’t get too sweaty when the temperatures warm up.
Long days standing on pegs? The 8.5 boot’s ankle design offers stability when riding on the balls of your feet, aided by an extended foot peg riding zone for arch support when standing. The sole’s dual zone hardness blends durability with peg feel and grip, with the flat inside of the boot keeping the rider in touch with the bike.
And what about all the other stuff we use our feet for? A quick dab to catch balance, walking around exploring the landscape, or pushing the bike when we’ve given up trying to ride over an obstacle? The 8.5 has been created with exactly these in mind.
The enduro-style lower part of the boot with its off-road hinge structure offers support, with the soft nubuck leather upper (borrowed from Leatt’s ADV 7.5 boot) boosting comfort. And despite everything that’s been crammed into the boot, including aluminium and stainless-steel buckles and large reinforced shin plates, Leatt has still managed to keep the weight down.
ADV X-Flow 7.5 Short Boot
£239
Leatt 7.5 X Flow Boots
Hot days, long miles, mixed terrain. This is where the Leatt ADV X-Flow 7.5 Short Boot comes into its own. Instead of roasting your feet in a traditional tall adventure boot, the X-Flow 7.5 is built to keep you cooler and more comfortable. A perforated construction combined with Leatt’s X-Flow mesh channels airflow directly to your foot, helping reduce heat build-up when the temperature climbs.
The low-cut adventure design offers the freedom to move naturally, whether you’re working the pegs through a rocky section or stretching your legs at a fuel stop. It’s noticeably less restrictive than a full height boot but still delivers protection where it matters most. Ankle impact foam, shin reinforcement, and carefully engineered flex control focus on key zones without making the boot feel bulky or overbuilt.
On the bike, the low-profile toe box and adventure-focused sole are designed for better feel and control when changing gears, braking, and riding in the standing position. The result is more precise input with less effort, especially on technical trails.
Fiddly buckles and laces have no place on big days out, so Leatt uses its SlideLock closure system. Pull it on, slide it shut, and the top of the boot seals quickly and evenly for a secure, fuss-free fit.
From highway stints to gravel shortcuts and all-day detours, the Leatt ADV X-Flow 7.5 Short Boot is purpose-built for mixed ADV use, striking the sweet spot between breathability, grip, support, and day-long comfort.
It’s about the journey
As every adventure rider knows, it’s not about the destination, it’s about the journey, and the Leatt team are still on theirs. The brand continues to innovate and improve and the range of adventure gear available in 2026 is testament to that.
To find out where you can buy Leatt’s adventure range, visit its distributor Apico Factory Racing’s website HERE.
