Bridgestone Battlecross E50: 4 things we learned after two months on the trails
If there’s one component that defines the performance of your motorcycle, it’s the tyres. Fit the right rubber and every ride becomes more enjoyable. Get it wrong and even the best bike in the world will struggle to deliver.
That’s even more true when riding off road. Head out onto muddy trails with the wrong tyres and it doesn’t matter how many riding modes or how much power your bike has. If the tyres don’t grip, the ride quickly becomes hard work.
tyres on my KTM EX-C250
So, when it came time to replace the tyres on my KTM EX-C250 6Days, I fitted a set of Bridgestone Battlecross E50 tyres, running a 90/90-21 front and 140/80-18 rear, the standard fitment for the KTM.
The Battlecross E50 is designed specifically for enduro and serious trail riding, and I tested it over two months during the winter, covering hundreds of miles of muddy green lanes, rocky tracks, deep ruts, and more.
Here are my four main takeaways…
1. Block Party
One glance at the tread pattern tells you these tyres mean business. Large, widely spaced tread blocks cover the carcass of both front and rear tyres, creating an aggressive pattern designed to maximise traction in mud and loose terrain.
Those wide gaps between the blocks allow the tyre to clear mud quickly, maintaining grip where many tyres clog up and lose traction. Each tread block also features Bridgestone’s Castle Block Technology, which is a block within a block design that increases the number of biting edges. The result is improved traction when accelerating, braking and cornering in slippery conditions.
2. Strong Performance Across All Surfaces
Bridgestone Battlecross E50 on a motor bike
Despite the aggressive tread, the Battlecross E50 is far from a one trick pony. From hard packed gravel roads to loose shale climbs, flooded rocky lanes and root infested forest trails, the tyre delivers consistent grip across a wide range of surfaces.
This versatility is particularly important when trail riding in the UK, where conditions can change dramatically within a single ride. One moment you are climbing a rocky lane, the next you are negotiating deep mud or wet woodland.
The E50 offers excellent traction on rocky surfaces while still delivering the mud performance a trials tyre often lacks.
3. Confidence in the Corners
aggressive tread of the Battlecross E50
Rear traction is important, but if the front tyre will not hold its line in slippery conditions your confidence disappears quickly. UK green lanes are often deeply rutted, and staying in the chosen line can make the difference between flowing along the trail or fighting the bike.
The Battlecross front tyre mirrors the aggressive pattern of the rear but features a carefully designed block layout along the sidewalls to improve cornering grip. The result is excellent stability when riding through ruts or loose turns, while the central tread pattern maintains strong straight-line traction.
4. Surprisingly Good Road Manners
Bridgestone Battlecross E50 off-road tyres
While the Battlecross E50 is built for dirt, it behaves impressively on the road too. Considering the relatively small contact patch of an aggressive off-road tyre, the level of grip and feedback on tarmac is surprisingly reassuring.
You are not going to be scraping pegs through corners, but for riding between trails, the tyres provide predictable handling and decent grip, even on wet roads. For riders who regularly link trails using public roads, that balance is extremely welcome.
Read the Full Review of the Bridgestone Battlecross E50
motor bike with Bridgestone Battlecross E50 tyres
So, there you have it. My four main takeaways from two months spent riding on Bridgestone’s Battlecross E50 tyres, and what fun I’ve had. But there’s so much more to tell you about them, which is why I’ll be writing an in-depth review in the May/June issue of Adventure Bike Rider magazine.
