volt meter would like to connect to spot light switch/source GS1200
IntruderWithin
Morning, as the weather is sooooo bbbaaaddddd today i would like to install my volt meter. looking around the bike the one place which could work is by connecting it to the spot light switch. There are three wire : purple, white and black. Which would be the positive white or purple?
- bikeswitch.jpg (33.21 KiB) Viewed 2293 times
At times of peace, plan for war.
Re: volt meter would like to connect to spot light switch/source GS1200
Surely the volt meter is the best way of finding out
IntruderWithin
yeah but i dont want too splice all the wires..
Try this site check out wiring diagram at bottom of menu
http://www.r1200gs.info/
IntruderWithin
thanks connected to the white and ran the black to battery works sweeeeeet
peterekins
Why fit a volt meter? Surly to see if your charging or discharging you fit an amp meter.
Oop North John
- Has thanked: 154 times
- Been thanked: 199 times
A volt meter will give a relative indication of what's happening, eg most systems seem to run at about 14.2 volts, start adding in heated jackets / grips etc etc and the voltage seen on the gauge will drop. From experience if you see x.xx volts you know that the battery isn't being charged.peterekins wrote:Why fit a volt meter? Surly to see if your charging or discharging you fit an amp meter.
