Linked brake's
clutchspring
Has thanked: 6 times
Been thanked: 31 times
Linked brake's
Post by clutchspring » Fri Apr 27, 2018 2:13 pm
Hi , need some advice regarding MOTS & linked brake's .
Just been checking my Varadero over ready for the MOT & found out the rear brake's not working via the front brake which it should .
The rear break pedal is still. Operating the left hand front brake which it should do via the linked braking systems fitted to this bike.
Back brake still works fine as does the front , what I would like to know is would this be a MOT failure !
Thanks,
Ian.
Cone
Has thanked: 153 times
Been thanked: 246 times
Re: Linked brake's
Post by Cone » Fri Apr 27, 2018 2:34 pm
Lol I’d be more worried about the fronts failing if the link has failed, not that I know anything about the brakes on a varadero
Seriously I wouldn’t sit on that
AlanHolt
Has thanked: 252 times
Been thanked: 286 times
Re: Linked brake's
Post by AlanHolt » Fri Apr 27, 2018 4:16 pm
As the rear brake is operating itself and the front left, it sounds like a faulty delay valve (£190 part).
Stewie
Has thanked: 431 times
Been thanked: 318 times
Re: Linked brake's
Post by Stewie » Fri Apr 27, 2018 4:59 pm
I don't know if they are the same as the Blackbirds link brakes, but first I would be giving the system a service, but as said if it's not working as it should I wouldn't be riding it, as for the MOT as long as each wheel stops as it should it'll pass.
Jak*
Has thanked: 164 times
Been thanked: 258 times
Re: Linked brake's
Post by Jak* » Fri Apr 27, 2018 5:04 pm
I have no experience of Honda's system but every time I take my Guzzi for MOT I point out they the brakes are linked. They still only test the back and the right front disc and it passes every time on 2/3 of its braking power.
Cheers Jak
sprintster
Has thanked: 105 times
Been thanked: 70 times
Re: Linked brake's
Post by sprintster » Fri Apr 27, 2018 5:16 pm
I'd have thought if the lever stops the front wheel and the pedal stops the back it will still pass.Your brakes would have to be seriously shit to fail when you think a 30 year old drum brake can pass.
Tourider
Been thanked: 8 times
Re: Linked brake's
Post by Tourider » Fri Apr 27, 2018 5:18 pm
The test is the same as for normal bikes, so the front brake lever is used to test the front brake and the pedal to test the rear.
Craig-SM
Has thanked: 27 times
Been thanked: 42 times
Re: Linked brake's
Post by Craig-SM » Fri Apr 27, 2018 6:17 pm
The brakes are tested independently so the tester would have no idea that the linked system wasn’t working.
herman
Has thanked: 878 times
Been thanked: 631 times
Re: Linked brake's
Post by herman » Fri Apr 27, 2018 7:13 pm
At my last MOT he tested with the ignition off which disabled the linked system after me telling him to watch out for the brakes. Passed obviously
scotsy
Has thanked: 23 times
Been thanked: 46 times
Re: Linked brake's
Post by scotsy » Fri Apr 27, 2018 7:49 pm
Blackbirds CBS linked brakes only work like that when the bike is moving forwards.
The LHS front caliper gets 'rotated' slightly on a pivot fixed to the LH fork leg, this only happens when the wheel is moving forwards AND the front brake is applied. This 'upward' movement applies pressure into an extra master cylinder piston that is connected to the LH fork leg and rear brake caliper and applies some braking at the rear wheel.
A mate of mine had his blackbird fork legs powder coated and after refitting them he had a 'glowing' rear disc. It turned out that the 'LH pivoting caliper was too tight on the powder coated mounting lug and was sticking after releasing the front brake and therefore still pressurising the rear caliper which caused the rear brake to overheat and could have been very dangerous if it had gone unnoticed.
We sanded away the powder coating on this 'lug' and put a touch of copper grease on it so that it was free to 'pivot' again and it was cured.
ian
Users browsing this forum: Mactavish and 49 guests
