Anyone made their own screen or work with perspex/acrylic?
Q plate
Has thanked: 51 times
Been thanked: 19 times
Post by Q plate »
So I've managed to break the lower part of my screen (2 part isotta) and looking at about £200 to replace it but I've got a sign shop at the bottom of the road and I've had various bits of offcut sheet to make/repair easy stuff but I wondered if anyone's had success with heating and shaping something like this
in an uncontrolled environment ie the shed. If it was the top part it would be relatively straightforward but the lowers got all the curves/form?
Any advice appreciated..even if it's give it a miss and get your wallet out (thumbs)
big al
Been thanked: 48 times
Re: Anyone made their own screen or work with perspex/acrylic?
Post by big al »
Hi Al (thumbs) .
I've made a few screen spoilers from macrolon, acrylic and shaped them in various curves by heating them up gently and securing them in the required shape untill cold.
hope this helps.
Al
Andi_Archer
Has thanked: 3 times
Been thanked: 126 times
Post by Andi_Archer »
Your probably going to have to make a wooden former,lay the sheet over it and then heat its up so it forms to the shape.Much like they do in that U.S. fish tank reality series Tanked.
mjojom
Post by mjojom »
or, get the "glue" for acrylic. see you tube how it works, cost peanuts and it actually works great - it thats a clean break without dirt. two parts must be perfectly aligned. if for nothing else, it will retain its shape so you can bend new perspex around it to exact shape (thumbs)
jasperthedog
Has thanked: 24 times
Been thanked: 6 times
Post by jasperthedog »
You can use the original acrylic to make a plaster mould, a male and female makes it easier but not necessary and heat it carefully with a hot air gun. If you have a friendly t shirt printer close by a heat press works well.
If your ever near leicester your welcome to use mine.
Dark Knight
Been thanked: 99 times
Post by Dark Knight »
In the 1970's when I needed a bike to get back on the road, a mate gave me his old BSA Bantam in bits as he was moving down south.
Rebuilt it, but needed a screen so I bought a sheet of perspex and used a fan heater to shape it over my knee, worked perfectly.
Q plate
Post by Q plate »
Thanks for all the replies Gents appreciated looks like it's worth a go rather than a non starter i'll source an offcut or 2 :whistle: and see how I go (thumbs)
Sanqhar
Has thanked: 15 times
Been thanked: 98 times
Post by Sanqhar »
Overheat with a heat gun and the plastic surface wrinkles so be careful. I have used an electric halogen hob with some success, wife now has an induction hob so have to use the heat gun.
Tom
fazernash
Has thanked: 26 times
Post by fazernash »
Hi q plate
Have a similar screen from a 2009 800 gs. I'm in Co Durham area DH2, if your interested.
Cheers Stu.
Q plate
Post by Q plate »
Cheers Stu pm sent
