Chainsaw oil in scottoiler
anthony29040
Has thanked: 6 times
Been thanked: 61 times
Post by anthony29040 »
Anyone used chainsaw oil in a scottoiler.it's getting expensive scott oil or is it me being a tight arse.to me chainsaw oil looks to be the same stuff but you can get 5 litres for the price of 1 litre of scott oil.any feed back would be great good or bad.cheers tony.
viince
Been thanked: 2 times
Re: Chainsaw oil in scottoiler
Post by viince »
used it for the last couple of fills seems ok (thumbs)
I'm sure the right tight wads will be along shortly to recommend other types :P :P
cheers vince (thumbs)
DaveCon
Has thanked: 102 times
Been thanked: 100 times
Post by DaveCon »
Any oil will work in a Scottoiler. The advantage with chainsaw oil (and slideway oil which is what I use) is that it has an adhesive component that acts as "anti-fling".
The disadvantage of the adhesive component is that it looks dirty whereas plain oil like a multigrade or monograde will be nice and clean.
HarveyCamm
Has thanked: 76 times
Been thanked: 127 times
Post by HarveyCamm »
A mate of mine uses saw oil poured on from a bottle and swears by it, I'm sure there must be technical differences but to most of us it's just oil for chains, cheaper by the gallon too ;) and you can get bio-degradeable chain-saw oil
Harv
bikenav
Has thanked: 1187 times
Been thanked: 761 times
Post by bikenav »
use oil I uh "obtain" probably not perfect but its free therefore negates possible slight extra chain wear, tight Welshman see.
GraySWTRF
Post by GraySWTRF »
Used it for years but I squirt a bit of WD40 in with it to try and thin it out a little.
anthony29040
Well I am glad to see its not just me.thank all you tight arse.lol (thumbs)
Nick_2112
Been thanked: 6 times
Post by Nick_2112 »
I read recently that 'Rock Oil' chainsaw oil is 'very similar' to scottoil, costs about £18/5L.
MarcusRothwell
Post by MarcusRothwell »
ONLY IF ITS ANTI FLING TONY, FED UP OF GETTING COVERED IN IT!
bowber
Has thanked: 34 times
Been thanked: 179 times
Post by bowber »
The cheapest ATF I can find, usually in a 25l container in the bus garage about 10m from me :whistle:
