All parts are in sealed bags or bubble wrap and only removed from the box for picture
I have a set of these on my K8 DL650 and was so impressed with the heated grips I purchased a second set (along with other parts) as I intended to buy a K3-K9 DL1000
Due to ill health the purchase of a DL1000 has been shelved so I am having a clear out
The part number on the box is SP100-06871
Instructions have part numbers 57100-06861 & 57100-06871
Suzuki GB list them to fit DL650 - K4-K6 DL1000 K3-K9 but I have fitted the same part number kit to my K8 DL650 with only having to adjust the throttle cable free play but please check
Kit includes...
Heater Wire x1
Heater Switch x1
Switch Bracket x1
Grip L x1
Grip R x1
Clamp x2
Screw x2
O Ring x1
Installation Instructions x1
They are not cheap but after trying various aftermarket grips these are the only ones I have found to be very warm and last more than a season,
I'm sure someone will post "you can get heated grips for £50" but these are a direct fitment with the correct length plug and play wiring, fit without having to reposition switchgear as the grip is too long,do not catch the hand guards and do not rub on the throttle side bar end as cheaper heated grips do
RRP on Suzuki ebay shop is £293.74 inc post
£190 inc recorded UK mainland postage
Thanks for looking
