How square is too square?
Toecutter
Post by Toecutter »
Noticed the Conti Trail Attack 2 on my rear has a bit of a flat spot round the middle. Handling's unaffected so far, and there's plenty of tread left right across, but i'm just wondering how people feel about squaring off and how far you let it go before swapping out the tyre. I've done just over a thousand miles on it, but i don't know how many the previous owner did. Can't be that many, the bike had only done 1500 when i bought it, and it's not the original Scorp trail like i still have on the front.
ollydog
Has thanked: 61 times
Been thanked: 18 times
Re: How square is too square?
Post by ollydog »
quite a bit of chicken strip showing there, if you can feel the bike drop into a corner then its prob time to change, unless you are running summat like a dunlop 207 rr which has a very steep profile for fast directional changes.
these look pretty new can you see the lettering in the rubber the flat you can see, i think you are quite a far way off changing.
steve
qcnr
Has thanked: 729 times
Been thanked: 260 times
Post by qcnr »
I run Heidenau K-60s and wore the last one untill it was almost ( about 2mm of tread) bald in the centre. Plenty of tread on the sides and didn't really notice anything
handling wise. Still went round corners, but then I'm no Rossi...
Redmurty
Has thanked: 337 times
Been thanked: 153 times
Post by Redmurty »
I change a squared off tyre when I feel that I am tipping over an edge, or you can go and find lots of corners to play in and round it off a little again.
Change it if your not happy (thumbs)
cheers Spud ;)
johnnyboxer
Has thanked: 118 times
Been thanked: 555 times
Post by johnnyboxer »
Looks fine, I'd get 10,000 miles out of that tyre :whistle:
My rear Conti TA2 is loads more squared off than that :blink:
IainD
Post by IainD »
It looks OK to me, some way to go before needing replaced.
You will feel the edge when it gets bad, however don't overlook the condition of the front, this usually starts to form a v as most of the wear occurs cornering. This exacerbates the tipping feeling, but can hide it if little worn. Always treat them as a pair.
Toecutter
Post by Toecutter »
Good advice, folks, thanks. Like i said the handling's still fine just now, i'll keep an eye on it and change it if it starts to feel a bit squirrelly. Good point about the front too. Just had a look and it seems fine.
Thanks
Emf#53
Been thanked: 2 times
Post by Emf#53 »
Don't worry about it until you get off the bike and you don't need to use the side stand as it'll stand up on it's own (thumbs)
JJay51
Has thanked: 40 times
Been thanked: 70 times
Post by JJay51 »
Ride some proper back roads and it'll even off :D
