My Zumo seems to be brain farting, will work for about 30min then decides it can't find where it is going and looses all the map.
When switched off and on again all ok...
Any Ideas?
Have just updated and still the same problem...
Zumo 550?
Re: Zumo 550?
My Zumo 400 will 'die' in very hot conditions, I unscrew the battery and then reconnect and its good to go again, don't know if that is any help :side:
Re: Zumo 550?
don't know if this is the same issue,
a couple of years back when I had my 550
had a similar problem
working ok then freezing up
turned out to be a conflict of maps
depending which program you use to plan trip
could be a slightly different (earlier/later) map set
causing the unit to hang or crash
hope this helps
you could try a post on
http://www.zumoforums.com/
if no luck on here
cheers vince
hope this helps
if no luck on here
cheers vince
- Has thanked: 12 times
- Been thanked: 6 times
- Has thanked: 3467 times
- Been thanked: 1823 times
Re: Zumo 550?
Yep mine brainfarts a lot more so in hot conditions , just turns itself off !!! ball ache really cos when i turn it on again it need to go through all the agree shite
Been looking at S/H zumo 660 but price is way to much ......looks like i'm sticking to "PAPER"
Re: Zumo 550?
You know me to well Russ , yep its a nuvi not a zumo !!!! both bloody stupid names but i'll bring it along , have you had a look at the weather for then
