Yeh, thanks Mr. Haynes
The nut came off no worries, and the bolt turns pretty much 360 with a socket spanner on it; the bolt still hasn't drifted after shredding the thread and whacking the bolt end for ten minutes, first with a drift and then brute force and ignorance against the bolt end in itself...
It's the bolt on the suspension linkage that drops away and lets me access the actual bolt that holds the bum end of the shock, any tips on drifting the bolt thru appreciated
I've drilled a one out before on a Yam, but this Honda has needle bearings in it and if it needs drilling well, so be it but if there's a less destructive way then I'd like a couple of pointers...
