As per title jm noticing a lot of black carbon soot on the silencer outlet of my xt660z...after using the new e10 from shell fuel mainly...
Commuting 40miles round trip each day on motorways so about 65mph upwards...4000rpm mainly ...I've changed nothing on the bike but lots more soot on baffle at tip..
E10 carbon soot on silencer
- Has thanked: 295 times
- Been thanked: 133 times
Re: E10 carbon soot on silencer
I had XT600 way back in early 90's. Nice bike, I miss it.
I'd pull the plug and check if it's running a bit rich. Then either adjust fuel mixture (maybe a bit difficult with fuel injection) or try different temperature sparkplug. You could also have an engine that is about to fail and be burning oil (Aren't I a beacon of joy today? ).
- Has thanked: 2282 times
I would say Don't change the plug heat range .. bad experience had, o dear.
But definitely check and probably change the plug.
Check all maintenance up to date, especially oil.
If its dct, don't think so, do a dct reset.
Change your mode of riding, possibly, to allow good clean combustion over 20 miles. Check air filter.
Maybe rev it more.
Try E5
. More power and probably cleaner burn.
Just basic stuff really.
Maybe check battery and connections?
Possibly some redex or similar?
Maybe rev it more.
Try E5
- Asgard
- Has thanked: 174 times
- Been thanked: 381 times
Thinking back to my youth, I seem to remember that the model engines I played with that ran on Methanol ran cooler than similar petrol engines, I wonder if temperatures including exhaust gas temperatures reduce to a noticeable degree with increased alcohol percentages
- Has thanked: 138 times
- Been thanked: 246 times
I am only filling up with Shell V-Power ; rated at 99RON , it works out at about the extra cost of about a couple of quid and I think it is worth the extra.
BP’s is only 95 RON for the same price.
Is the performance any better? Probably not but hopefully the longer-term advantages will justify the cost.
Supermarket E5 if necessary but never E10.
As I only use the bikes for pleasure, I can justify to myself the extra cost of a latte to fill up.
I believe the percentage of ethanol is variable, as stated as 'up to' say 5% or 'up to' say 10%. This will depend on what's available, oe region or circumstances etc. So you can't even judge or allow for the petrol type.
Around here, my local petrol station does 5%, and you can feel the 'upgrade' in power .. though of course its still not as good as unleaded, or, the leaded.
I have not yet found a petrol station for 5% in mid or west Wales. So I sometimes try to work it that I am close to empty when arriving home, sos I can fill up, on the way out for a run, at my pokey little local.
As Paul says, the difference in a tank full is only a few quid, but the feel of my nc750s is transformed, even though it is labelled for both 5% and 10%. I wouldn't recommend putting a latte in though.
I still think the OP problem is down to maintenance though.
That's amazing.. I was thinking about Haverfordwest tesco just yesterday, as a cafe stop for a run.
So cardigan tesco do E5 too ?
Yes, Cardigan too.
Gary,
Great cafe at the airport in H’west: ‘Propellors’
