KTM Banner
Author: Alun Davies
SHARE ON:
For the answer, maybe we should look at what we do know; Yamaha have suffered serious financial losses over the past year; motorcycle sales are generally in decline; we are in tough economic times and it’s looking like it’s going to get worse before it gets better. Add those three known facts together and from a business point of view, it’s not healthy to be holding large quantities of stock of a new and untried product, especially one that is priced at the top end of a market that contains some serious competition – BMW and Ducati to name but two.
Under the circumstances, this feels like a made to order policy – I’ll try and get a handle on delivery times which may offer more insight into that – and I’d expect to see Yamaha rely more on extensive below the line PR campaign rather than a full on advertising blitz. We’ll see.
However, two things are for sure; Yamaha know how to build adventure bikes – the XT500 was arguably the first of the genre – and that shaft drive is going to be a lot slicker than some others on the market. All in all, and certainly on paper, the new Super Tenere 1200 has the makings of a classic though wouldn’t it be nice to pop into the dealers for a confirmation test drive.
Anyway, the Yam PR department is well under way with their ‘Ride For Life’ campaign with 7 Super Tenere’s just about to depart from Paris en route to Marrakesh. On the Paris to Lisbon leg the bikes will be ridden by ‘celebs’ which include Helder Rodrigues (4th in Dakar 2010) whilst the remaining stretch down through Morocco will feature 7 (or is it 5, their website says both) lucky members of the public one of which is Brit Jonathan Geoffrey. On arrival in Marrakesh, 5 Super Tenere will be donated to Riders for Health, an organisation dedicated to help bring heath facilities to outlying regions of Africa by way of motorcycles.
Shaft drive inline 2-cyl engine – 270-degree crank
Mass kept low and central for agile handling
Intelligent Unified Brake System and ABS
YCC-T with 3-stage traction control plus Yamaha D-mode First edition adventure pack Tough spoked, tubeless aluminium rims
Adjustable front and rear suspension
Adjustable seat height
Engine
Engine type: liquid-cooled, 4-stroke, DOHC, Forward-inclined parallel 2-cylinder, 4-valve, fuel injected, twin spark engine
ABR Internal 1
Displacement: 1199 cc
Bore x stroke: 98 x 79.5 mm
Compression ratio: 11.0 : 1
Maximum power: 80.9kW (110PS) @7,250rpm
Maximum torque: 114.1 Nm(11.6kgf+m) @6,000 rpm
Lubrication system: Dry sump, oil tank in crankcase
Carburettor: Fuel injection
Clutch type: Wet, multiple-disc coil spring
Ignition system: Twin spark
Starter system: Electric
Transmission system: Constant mesh, 6-speed
Final transmission: Shaft
Fuel tank capacity: 23 L Oil tank capacity: 4.2 L
Chassis
Chassis: Steel tube backbone
Front suspension system: Telescopic forks
Front travel: 190 mm
Rear suspension system: Monoshock, adjustable preload and rebound damping
Rear travel: 190 mm Caster angle 28° Trail 125mm
Front brake: Hydraulic Twin Ø 310 mm wave discs
Rear brake: Hydraulic Single Ø 282 mm wave disc
Front tyre: 110/80R19M/C 59V
Rear tyre: 150/70R17M/C 69V
Dimensions
Length (mm): 2,250 mm
Width (mm): 980 mm
Height (mm): 1,410 mm
Seat height (mm): Adjustable 845-870 mm
Wheel base (mm): 1,540 mm
Minimum ground clearance (mm): 205 mm
Service weight (kg) 261 kg
Links
Super Tenere Ride For Life
Yamaha Super Tenere 1200
ABR Internal 1
SHARE ON:
