Dose any one use one of these on a R1200GS
If so how do you get on with it ,is it safe to wire straight in to the battery with the supplied socket and charge while the battery is still connected and on the bike ?
OPTIMATE 3+ MOTORCYCLE MOTORBIKE BATTERY CHARGER
Re: OPTIMATE 3+ MOTORCYCLE MOTORBIKE BATTERY CHARGER
If the 1200 has canbus, you will need the Optimate 4 rather than 3 as the 3 is not compatible with BMW canbus systems
With the 4, I think you can get an adaptor to plugs staight into power socket on the bike and charge through that (if its the same as my F650GS twin)
Hope that is of help
There's two versions of the '4' you'll need the 'OptiMate 4 Dual'
I use an old optimate on my bikes. If you wire the lead directly onto the battery it will be ok, or if you fit an aux socket wired direct to battery you can plug in using a BMW type din plug (this is what I do)
It will not work in the standard aux socket because of the canbus system, or you can bypass that as above.
Hope that makes sense :huh:
BMW R1200 GS Adventure
KTM 990 R Adventure
Wheresoever you go. Go with all your heart.
KTM 990 R Adventure
thanks to you all ,that the answers i was hoping for as i have the 3 ill go straight off the battery with the supplied lead that came with it
cheers
cheers
- Steve T
- Has thanked: 268 times
- Been thanked: 855 times
On my F8GS I've wired an Optimate style connecter direct to the battery without any problems. Bikes been on & off it for the last 2 months since the frosts started up here.
Steve T
B)
Steve T
B)
ZEN DOG
Hi I use the optima the 3 and bought the waterproof lead from the battery from ebay , No issues
At times of peace, plan for war.
