wondering if anyone could recommend a ram mount to use on the bar above the speedo on the ten. i have one from my old TA but it seems to be a bit loose on the bar and wont tighten enough. any help would be appreciated.
thanks dan
Ram mount xt660z tenere
- gebrauchtwagen83
- Has thanked: 1 time
- Been thanked: 4 times
Re: Ram mount xt660z tenere
i use the ram mount that was supplied with my tom tom urban rider its the "u" shackle type mount,i had to file the bottom of the mount to get it to clear the fairing undernearth the bar
- Has thanked: 572 times
- Been thanked: 894 times
i cant remenber the model number dav but
this has stuck on the top bar with a bit of rubber matting and never been a problem ..never ever budged .. i think the triangle shape of thegrab is imprtant ..or was it the bottom spacer ...i seem to remember theoriginal handlebar one .. had no bottom spacer thingy and ended up with this ...
which cured it
this is the pic uploaded a year ago also doubled up as a handy camera mount ...at least its a close up of the bar thingy
..hope this helps
By minkyhead at 2011-03-22
By minkyhead at 2011-02-07
By minkyhead at 2011-02-08
which cured it
..hope this helps
- gebrauchtwagen83
many thanks. yours minky looks the same as mine except i dont seem to have the bottom spacer.
