My tdm running bad.
Lord Reeper
My tdm running bad.
Hello there just got myself a 1992 tdm 850. . It ran rough just after I got it. I replaced reg rec. And stripped replaced carb seals and emulsion tubes . It runs a lot better when I rev it up. But wont tickover. as if drawing to much air. I have reduced the large breather pipes at top of carbs to narrower . Any ideas
- Elmer J Fudd
- Has thanked: 77 times
- Been thanked: 222 times
Re: My tdm running bad.
Could be carbs out of balance, holed air filter or airbox connection, sticky flaps, bad / contaminated fuel?
Contact the previous owner, OK they may deny all knowledge, but they may be able to help if has occurred before.
Is there a specialist tedium forum?
Dark Knight
- Been thanked: 99 times
Those TDM's were built to last forever.
Well its either carburation or ignition.
Maybe need to put the jets through the ultrasonic cleaner if you believe that the Carbs are properly balanced.
Not sure what the electronic ignition is like in terms of reliability on those models.
If all else fails, you could always go into your local Yamaha dealer and speak to one of the mechanics, he may just come up with a comment that solves your problem.
Lord Reeper
Thanks for advice. It's been a pain so far. Previous owner no help. I.ll sort it thanks.
Tonibe63
- Has thanked: 1539 times
- Been thanked: 690 times
Great bikes.
They were known for problems if the carbs are not balanced accurately, there is a linkage between the two carbs and from memory the haynes manual tells how to set them up.
Carpetdm is also a great font of knowledge.
Brenhden
- Has thanked: 1187 times
- Been thanked: 734 times
Love a pun name
Suzuki DR200 Djebel.
Dark Knight
Was thinking that it could be an air around the caburator area (rubbers getting hard), maybe trying spraying with some soapy water or similar, you might be lucky.
