Suzuki DRZ400S parts for sale
boboneleg
Has thanked: 2496 times
Been thanked: 1485 times
Post by boboneleg »
Genuine Suzuki rack, some paint loss, could do with a clean £35 plus £7.50 next day delivery
Large capacity tank ,I believe it's an IMS but not certain. Decals can easily be removed. £160 plus £10.00 next day delivery
one-legged adventurer
boboneleg
Re: Suzuki DRZ400S parts for sale
Post by boboneleg »
boboneleg
Post by boboneleg »
DRZ400S rear subframe, this is useful if the have the 'E' model and want to carry luggage. Decent condition but needs a clean. £50 plus £10.00 next day delivery.
boboneleg
Post by boboneleg »
I am stripping a 2001 DRZ400S for a mate which developed a gearbox problem, bike has done 25,400 miles. Engine, Frame (with V5) for sale plus lots of other bits.
Please ask if there's anything else you're interested in
dave j
Has thanked: 12 times
Been thanked: 6 times
Post by dave j »
Buonasera Bob! Come stai!
Re: the tank, do you how many litres it holds?
Dave Jones
KTM 1290 Super Adventure T - Power!
KTM 690 Enduro R - lighter to pick up
Husqvarna Svartpilen 401 - Fun.
Even our dogs are orange.
Only bikers understand why dogs put their heads out of car windows.
frenchy3
Has thanked: 367 times
Been thanked: 108 times
Post by frenchy3 »
boboneleg wrote: Sun Nov 10, 2019 4:06 pm Large capacity tank ,I believe it's an IMS but not certain. Decals can easily be removed. £160 plus £10.00 next day delivery
Hi,i had one of these tanks on my DRZ400S It is the IMS tank and it holds 15.1 litres. You use the original fuel tap but on my S model i took off the potentially troublesome vacuum operated tap(you need to blank off the vacuum take off port on the carb) and put the standard E model gravity tap. I shortened my standard fuel hose and it fitted no problem. This model fits the E model as well but you just remove the metal bracket from the top of the tank which the bracket on the s model seat locates into and fit the E model fitting from the standard tank that the rubber securing strap fits to. This tank has had the extra bracing brackets fitted to the underside(optional extra) This helps support the front of the tank which is quite heavy when full. These tanks can cost over £300 when purchased in the UK so grab it quickly. This tank also protects the radiators when fitted. I did have a bit off a problem lining up the lower tank to radiator mounting bolts but this was because one of my radiators had taken a hit and twisted.Forgot to say you need to save the DRZ400s rear tank mounting rubber bushes and fit them to the aluminium brackets on the back of the IMS tank.
boboneleg
Post by boboneleg »
dave j wrote: Fri Nov 15, 2019 11:04 pm Buonasera Bob! Come stai!
Dave Jones
Hi Dave, thanks to Frenchy we now know :D The tap has already been converted and the bracket are there to fit it straight onto a 'S' model.
Long time no hear Dave, hope you're both keeping well.
cheers, Bob.
boboneleg
Post by boboneleg »
Bump
before it goes on ebay :)
Return to “FOR SALE - WANTED”
