Which Compressor?
FatFreddy
Has thanked: 204 times
Been thanked: 59 times
Which Compressor?
Post by FatFreddy »
Hi folks
I'm looking for a small (affordable?) lightweight portable 12V air compressor.
It doesn't have to be fast or powerful, just as long as it can re-inflate a flat tyre after a repair.
I'm obviously looking in the wrong places so can anyone recommend one?
Teflon Jnr
Has thanked: 8 times
Been thanked: 107 times
Re: Which Compressor?
Post by Teflon Jnr »
My dad has a slime one it works well does what its intended to do
herman
Has thanked: 878 times
Been thanked: 632 times
Post by herman »
Airman , had mine for years and for the money has a high output. Will pop tyre a back on its bead unlike some of the really cheap ones.
Has thanked: 330 times
Been thanked: 634 times
Post by Tramp »
Whatever you get deflate your tyre at home then try it.. If it dosent work send it back..
Most important bit is dont let it bounce around in transit and only use with bike engine running...
zimtim
Has thanked: 623 times
Been thanked: 548 times
Post by zimtim »
https://www.sportouring.co.uk/shop/acce ... -inflator/
Had one of these a few years now, good and compact.
Jak*
Has thanked: 364 times
Been thanked: 496 times
Post by Jak* »
Look on eBay at car ones. Most modern cars have no spare wheel, they have a puncture repair kit and compressor. I bought a Toyota one, it says on it that you should not run it continuously for more than 45 mins. It was cheaper than one that you can buy from Halfords or a garage and I have blown new tyres onto the rim with it.
Cheers Jak
Hugh
Has thanked: 879 times
Been thanked: 929 times
Post by Hugh »
For a new tubeless tyre the trick is volume not so much pressure. Sometimes tie a tourniquet around the central circumference.
Plenty of tyre soap and most importantly keep your fingers away from the rim :mrgreen:
WIBO
Has thanked: 612 times
Been thanked: 648 times
Post by WIBO »
I have one of these, albeit an older model......
https://www.motopumps.com/
:D
Will It Buff Out?
Nick_2112
Been thanked: 6 times
Post by Nick_2112 »
I have one of these, not too large and works fine, think I paid a tenner at a petrol station a couple of years back.
https://www.ebay.co.uk/p/AA-Compact-Tyr ... 2979379001
BobH
Has thanked: 48 times
Been thanked: 79 times
Post by BobH »
+1 on the airman. Took the plastic outer case off and it packs really small. Been used on many bikes for the last 3 years.
Return to “ACCESSORIES”
