Share your luggage knowledge pls.
Re: Share your luggage knowledge pls.
If the clearance between pipe and box is worrying in a heat transference way then face the box with either heat proof silicon sheet or plumbers mat. Or use it to keep the bacon toasties warm.
- Steve T
- Has thanked: 260 times
- Been thanked: 841 times
The original BM exhaust is a good bit fatter than the Akro, so if you had a clearance problem with the Akro fitted, you'll not get an original can onto the bike with the jesse pannier rails on
The rear hole on the Akro without the baffle in is a little bit under 2" wide. About half that with the baffle in. The small M5 bolt that holds the baffle in can easily fall out if not fully tightened. The baffle itself is a very tight fit, so unless someone has done what I've done and reduced the diameter of the contacing bit so that it fits in and comes out easier, you should be fine.
Steve T
Steve T
ZEN DOG
- FatFreddy
- Has thanked: 204 times
- Been thanked: 59 times
Thanks for the tip but heat transference isn’t going to be an issue. (As I’ll explain below).
- FatFreddy
The problem isn’t width, it’s length (as the actress said to the bishop).Steve T wrote: ↑Fri Dec 21, 2018 7:35 pm The original BM exhaust is a good bit fatter than the Akro, so if you had a clearance problem with the Akro fitted, you'll not get an original can onto the bike with the jesse pannier rails on
Steve T
The rails touch the pipe above (about where the pop rivets hold the carbon end cap on) and below, (on the end cap itself). I should take some pics and post them on here.
I have slipped a small piece of silicon rubber between the offending parts which should reduce any friction between them but won’t stop damage being caused in the long run.
Now tell me if this is a stupid idea folks.....
I HAD thought about cutting down the can. I’ve done it before, playing hooligan on road bikes, drill out the pop rivets at the inlet end (and back in the day, “accidentally” remove all the wadding), cut off a section of the can, drill new holes and pop rivet it all back together. But frankly that seems a little vandalistic with a lovely can like that.
So, how about if I slipped the can off, and cut a half inch off the pipe from the cat, where the slip on “slips on”?
It would still be a close fit but at least the can and pannier rails wouldn’t actually touch.
Stupid Idea??
- FatFreddy
Ah, Interesting, thanks Steve. From memory I’d say the outlet is just over an inch.... but my memory is rarely reliable so I’ll have a look. But maybe the baffle IS still in? If I post a pic would you give me your informed opinion? And if it is, and is a tight fit, maybe some advice on how best to remove it?Steve T wrote: ↑Fri Dec 21, 2018 7:35 pm The rear hole on the Akro without the baffle in is a little bit under 2" wide. About half that with the baffle in. The small M5 bolt that holds the baffle in can easily fall out if not fully tightened. The baffle itself is a very tight fit, so unless someone has done what I've done and reduced the diameter of the contacing bit so that it fits in and comes out easier, you should be fine.
Steve T
- cozi70
- Has thanked: 32 times
- Been thanked: 91 times
Like these,3 givi boxes for less than £100Richard Simpson Mark II wrote: ↑Wed Jul 25, 2018 10:38 pm Look out for bargains...I just got a pair of Givi Monokey boxes for £40 off Gumtree...they are red fading to pink though.
https://www.gumtree.com/p/cars-vans-mot ... 1331209265
