Pannier frame loops - precurved made up
Glenn_G
Has thanked: 3 times
Been thanked: 5 times
Post by Glenn_G »
Hi,
I'm looking to make another set of round steel tube rear pannier frames for my wk400, to take soft panniers.
My last attempt with a pipe bender/welder wasn't very pretty or strong.
So anyone know where I can buy pannier frame loops (OD~20mm & 2/3mm wall thickness) already precurved welded into a rectangular hoops.
I can then make weld up some support tubes to attach them onto my bike.
chubbyhooker
Has thanked: 35 times
Been thanked: 40 times
Re: Pannier frame loops - precurved made up
Post by chubbyhooker »
[img][/
img]i made mine from 2 cafe chairs
minkyhead
Has thanked: 572 times
Been thanked: 894 times
Post by minkyhead »
my skill set is not up to tubing ..but ive had decent results using light box section and flat bar ..much easier to work with than tubing and they are strong ..
Imageaaa by minkyhead56, on Flickr
Imageaaaaaaa by minkyhead56, on Flickr
ImageDSC_0793 by minkyhead56, on Flickr
diggermanbob
Has thanked: 803 times
Been thanked: 534 times
Post by diggermanbob »
If you put in pannier frames on eBay there is a set of hoops listed ,
Glenn_G
Post by Glenn_G »
cozi70 your 2nd link looks promising thanks
Chubbyhooker that's good recycling of chairs
Minkyhead thanks but I'm keen to learn/practise more with tubing as lighter. Looks strong.
Glenn_G
Post by Glenn_G »
'If you put in pannier frames on eBay there is a set of hoops listed '
diggermanbob so far only ones I can see are either too old/rusty, different diameter tubing or need some work - in which case it may be easier to start from scratch ... good idea though, ta
hotbulb
Has thanked: 89 times
Been thanked: 28 times
Post by hotbulb »
Minkyhead...... is the first set you picture wearing its woolly knitted jacket? :lol:
minkyhead
Post by minkyhead »
looks that way :D ,,its anti slip matting from poundland . high spec stuff indeed 8-)
Morph
Has thanked: 207 times
Been thanked: 92 times
Post by Morph »
