Hi All, was on a weekend break in the highlands and on day 3 the bike wouldn’t start.
Battery is strong, smelt like fuel was getting in and plug was wet. New plug and cap fitted but made no difference. I’m thinking coil. Anyone experienced this?
Xt660z not starting
Re: Xt660z not starting
Have you checked wether the lead will spark without the plug cap on?
Loose terminal on the low tension wire to the coil (check if the spade is tight on the coils terminal)
Bad earth where the coil mounts to the frame (take off and clean)
Kill switch problem (disconnect the 2 wires)
Sidestand switch (twist the 2 wires together)
Just a few thoughts
Good luck
Ian
Just a few thoughts
Good luck
Ian
- cozi70
- Has thanked: 32 times
- Been thanked: 92 times
Is the plug sparking ok when not inserted?
The collector blocks from the switch gear are located below the tank and are renowned for giving electrical issues.
Colin
Colin
Bigdavesmate
- Been thanked: 15 times
Sometimes the wiring loom under the tank can rub through due to vibration and earth the fuel injection wire against the frame so the injector stays wide open delivering too much fuel. Easy fix with the tank off, cut all the cable ties, re tape the bare wire and but a piece of rubber between the cable and frame. Then re cable tie it but not as tightly as during assembly.
This happened to me recently on the way back from the elefant in Germany on the side of a motorway in the pissing down rain!
My Tena lady is now affectionately known as the “bastard”
Too often I would hear men boast of the miles covered that day, rarely of what they had seen.- Louis L'Amour
Had this happen a few times on mine, especially in snowy / slushy conditions. The water droplets driven off the radiator blow onto the HT cable and you loose the spark. If the engine has been hot then parked up outside ovewrnight you get condensation, again on the HT lead. I always carry a small can of WD40 and spray the offending area and hey presto back into life.
Hope this helps.
- chunky butt
- Has thanked: 54 times
- Been thanked: 699 times
redbikejohn
- Has thanked: 2 times
- Been thanked: 95 times
Try cranking it over with throttle wide open. If mine stands in very cold weather for a few days it hates starting again.
Yamaha tenere 700
- chunky butt
Mine used to do that......now I turn on ignition and wait for fuel pump to prime.....Give it another 10 seconds and bingo, hope this helps.redbikejohn wrote: ↑Tue Mar 06, 2018 9:45 pm Try cranking it over with throttle wide open. If mine stands in very cold weather for a few days it hates starting again.
Ahhh this takes me back. I had the 660 engine in an Aprilia Pegaso trail (so pretty much the sameBiquad wrote: ↑Tue Mar 06, 2018 8:23 pm
Hope this helps.
It often would cut out while I was riding it
Despite that I loved the Pegaso and went all over the place on it until it started to fall to bits
Got bike started today after a tip from fellow rider. Try the red key he said. So I tried both black keys and no joy. Tried the red key and bike starts instantly. Tried the black keys again and bike starts no problem each time.
Would still like to know what caused the problem.
