Fitting a zumo 590lm
wispyone
Has thanked: 11 times
Been thanked: 3 times
Post by wispyone » Tue Jun 27, 2017 9:20 pm
Ok ok I know this has probably been done to death but spent an hour searching and still no wiser. I have just bought a zumo 590lm to put on my 2013 F800gs. Looking at all the wires it looks like it wires straight to the battery, is this the best solution or do I wire into the can bus system? If so how easy is it?
Also the 590 has a USB charger, where do people route this to? Leave under seat or route up around the bars for charging items in tank bag etc?
Thank you
Richard
Emf#53
Been thanked: 2 times
Re: Fitting a zumo 590lm
Post by Emf#53 » Tue Jun 27, 2017 9:24 pm
I wired my 595 straight to the battery
Not sure about the USB charger though - don't remember having one on mine - unless it was with all,the other cables that I just left under the seat.
wispyone
Post by wispyone » Tue Jun 27, 2017 9:37 pm
They definitely give you enough cable. I think there is an audio in, audio out, mic connector and USB charger. Will route most around under seat and cable tie in place, just not sure about USB cable
IainD
Post by IainD » Tue Jun 27, 2017 9:38 pm
Hi,
Use a supply direct from the battery through a relay with the control + tapped into a switched +.
Whatever you do, don't use the spare socket under the tank to supply the unit as the CANbus system gets confused and if the unit is left on the bike, a power draw drains the battery.
Something like a fuzeblock has a relay built in.
boatman
Post by boatman » Wed Jun 28, 2017 7:03 am
Dunno about the 800 but the 1200,s have a plug up under the dash that is provided for GPS ,just needs the correct flying lead to connect it
wispyone
Post by wispyone » Wed Jun 28, 2017 7:47 am
boatman wrote:Dunno about the 800 but the 1200,s have a plug up under the dash that is provided for GPS ,just needs the correct flying lead to connect it
Is this the can bus connection?
Will have a look this afternoon see if I can find it
Nigel
Has thanked: 151 times
Been thanked: 72 times
Post by Nigel » Wed Jun 28, 2017 8:24 am
Click here
Apophis
Has thanked: 4 times
Been thanked: 20 times
Post by Apophis » Wed Jun 28, 2017 8:34 am
You can get the lead from Bmw cheaper that getting from nippy normans
Then just supply a relay as already said in a previous post and supply the coil of the relay with the lead
Then just supply the relay direct from the battery and the relay will be switched 30 seconds after the ignition is turned off and the loss of power to the sat nav will auto turn off
Every day is an adventure
Nigel
Post by Nigel » Wed Jun 28, 2017 8:48 am
Apophis wrote:You can get the lead from Bmw cheaper that getting from nippy normans
True you just need the part number for BM dealer, I put in the link to explain how it fits, always fit lead to switched supply or you can get a ghost drain from sat nav cradle which can flatten the battery over time.
wispyone
Post by wispyone » Wed Jun 28, 2017 8:50 am
Am i correct in thinking that if I connect just through can bus with a lead from bmw or nippy Norman's then it will power down after 60 seconds without a relay?
As you can see wiring baffles the hell out of me
Users browsing this forum: AustinW and 60 guests
