James May The Reassembler Honda 50
catcitrus
Has thanked: 95 times
Been thanked: 448 times
Re: James May The Reassembler Honda 50
Post by catcitrus »
Paul_C wrote:He covered the Centrifugal clutch when doing the lawnmower in series one.
The suffolk lawnmower is no more than a couple of loaded brake shoes really. If you examine the Honda clutch closely it has a series of kidney shaped pressings mounted on a ring that pivot trying to provide centripetal force and clamp the plates (this is what I changed through CNC etc). The really clever bit is how this action is overridden by the gear lever via a worm drive and thrust bearing--once the gear lever is released the clutch can then operate. The engine started with a rather light pushrod C50 I think, and then gravitated through to an OHC 50 and then an OHC 90 , with a long stroke 90 as an "economy" version--but please correct me if I'm wrong. The concept lives on through pit bikes, small scoots and that odd Honda 125 which is a bit between the little "monkeybikes" and a normal 125. My involvement was using this engine in the Shell eco marathon--I built a hybrid 58cc with the 90 economy bottom end and a 50 barrel and head (LONG STROKE). 14:1 compression ratio, reprofiled cams, twin plugs AND multi spark, and progressive lean burn--starts on a carb but in a period of about 10s a stepper motor controlled air bleed into the inlet tract eventually leaned the mixture right out until it stopped. (about 3 or 4 10s bursts to get around Silverstone club circuit at an average speed of 15 mph--my record was about 2200 mpg (many years ago), but the record now stands at well over 10,000 mpg--its a serious business!)
ps hope this didn't put anyone to sleep before they got to the end!
vRSG60
Has thanked: 68 times
Been thanked: 86 times
Post by vRSG60 »
Hmmm, what's to say. Boring as fook that's what!
Earwig
Has thanked: 19 times
Been thanked: 54 times
Post by Earwig »
rlkat wrote:
PS. I do like James May. (thumbs)
I vote
:evil:
I like JM as well ... Intelligent guy, shame about the anorak :whistle:
[The extension has been deactivated and can no longer be displayed.]
rallymoto
Post by rallymoto »
turned it off bloody rubbish
macdee
Post by macdee »
Got any photos
And More info on the way you leaned the engine
catcitrus
Post by catcitrus »
I don't have any immediate pics(pre-digital)--and its a bit off topic--the leaning was accomplished by a "Y" inlet tract--normal carb on one and a "sealed" carb body on the other. The slide on this sealed carb was pulled up by a cable attached to a drum which was driven by a stepper motor--once activated on start up it lifted the slide gradually therefore leaning the mixture off gradually until after about 10s it was too lean to run--and "petered out"--best use of fuel and the faster the engine spins the more able it is to tolerate a lean mixture. If you wish to discuss it in more detail then we best start another thread--I like James May as well--maybe its because we are not normal "punters" that we find the programmes a bit trivial.
Scott_rider
Has thanked: 29 times
Been thanked: 294 times
Post by Scott_rider »
^...guys, I have absolutely no idea what any of that engineering stuff means because I'm a technical buffoon...but for some weird reason I like reading about it on here B) :silly: .
Mactavish
Has thanked: 147 times
Been thanked: 24 times
Post by Mactavish »
Could you start an other thread on the lean burn please . Found that very interesting .
catcitrus
Post by catcitrus »
Mactavish wrote:Could you start an other thread on the lean burn please . Found that very interesting .
Can I suggest that you guys that are interested in the tech stuff do a search on the Shell Eco marathon and start about 15 or so years ago and have a look at the engineering--not just the engines--way back Honda actually entered a factory team (and Ford)--Honda's engine was rumoured to be a 6 stroke and fuel injected. It gets silly--helium filled special tyres at extremely high pressure and so on--it will keep you amused for hours.
Brenhden
Has thanked: 1177 times
Been thanked: 727 times
Post by Brenhden »
Just watched this with my six year old daughter. Previous epispodes have sent her to sleep. This one had her laughing.
Suzuki DR200 Djebel.
Return to β€œTHE PUB”
