front brake stuck on !
Hi All, 1200 gs brake is stuck on and can only release after loosening the bleed nipple by the master cylinder .after a few pumps its locked back on again ? any thoughts folks
JonnyBravo
- Has thanked: 2 times
- Been thanked: 8 times
Re: front brake stuck on !
No idea old chap but you would do better to ask here -
http://www.ukgser.com/forums/forumdispl ... GS-Hexhead
they are the font of knowledge for all things panzer
good luck (thumbs)
good luck (thumbs)
sprintster
- Has thanked: 105 times
- Been thanked: 71 times
Dutchgit
- Has thanked: 40 times
- Been thanked: 5 times
Did you change pads recently ? There might be too much fluid in the master cilinder reservoir.
Or the plunger in the master cilinder doesn't come back all the way. Is there free play in the lever ?
catcitrus
- Has thanked: 100 times
- Been thanked: 467 times
The nasty little diaphragm washer should allow the pressure to release once you let go of the lever. Suggest that you try a bleed and "flick" the brake lever a few times--it may clear--if not its piston strip at the handlebar end --but if its ABS with all that servo sh1t then it could be anywhere in the system.
Big Yellow Tractor
