Steering head bearing replacement Tenere XTZ660
stephen.packer@gmail.com
Re: Steering head bearing replacement Tenere XTZ660
Post by stephen.packer@gmail.com » Sun Jan 24, 2016 5:40 pm
Gary117 wrote:
scottnet wrote:Thanks for the info. The removal tool looks good
Yes makes the job a lot easier.
I'm in Cheshire so if your local your more than welcome to borrow it.
The bearing on the stearing stem was very tight to get off so i used a dremel
I just use a length of steel rod (I think it's stainless, 10mm diameter) and a big heavy hammer.
Took me a few 'taps' to do top and bottom on my XT660; always helps if you have a good, solid, piece of wood below the steering head when you're bashing the bearing cup from above.
Also, removing the lower bearing race from the steering stem is a piece of cake with a 10 tonne press; just push the stem down about 30mm and then the bearing just drops off. It might need a bit of lubrication if it's been on for a long time.
WIBO
Has thanked: 552 times
Been thanked: 615 times
Post by WIBO » Sun Feb 14, 2016 11:22 am
As an aside I have this...a couple of pumps every month. Assists immensely after you change your bearings?
Will It Buff Out?
The Suit:What would you consider to be your greatest weakness?
Me: Honesty.
The Suit: Honesty? I don't think honesty could be construed as a weakness.
Me: I don't give a f**k what you think.
redbikejohn
Been thanked: 16 times
Post by redbikejohn » Sun Feb 14, 2016 5:45 pm
I found the xtz a bit difficult to get the bottom race out. Down it plenty of times on other bikes. Dirt bikes have a little cut out or the race protrudes slightly and a few taps and it out - but the tenere seemed to be almost flush so there was no purchase for the drift. On other bikes I've welded a small bar across and knocked out but this time I used a small cutter on my dremel to cut a couple of slots into the bearing and it came out. Need to do mine again so I might slot the head so make it easier next time. Another silly lack of attention by Yamaha.
XT660Z
redbikejohn
Post by redbikejohn » Sun Feb 14, 2016 5:47 pm
Good idea ref the grease nipple. I've done the same to a swingarm.
XT660Z
Users browsing this forum: No registered users and 73 guests
