Steering head bearing replacement Tenere XTZ660
scottnet
Been thanked: 2 times
Post by scottnet » Sun Jan 24, 2016 11:00 am
I am replacing top and bottom, I plan to use aftermarket bearings (complete set less than one OEM bearing from Yamaha and I am pretty sure its the same bearing) , but I am trying to figure out if there is a seal on the lower race. On the parts list I have it just shows the bearing. Has anyone done this and figured out if there is a seal what part number it is ?
Thanks
Scott
Gary117
Re: Steering head bearing replacement Tenere XTZ660
Post by Gary117 » Sun Jan 24, 2016 3:30 pm
scottnet wrote:I am replacing top and bottom, I plan to use aftermarket bearings (complete set less than one OEM bearing from Yamaha and I am pretty sure its the same bearing) , but I am trying to figure out if there is a seal on the lower race. On the parts list I have it just shows the bearing. Has anyone done this and figured out if there is a seal what part number it is ?
Thanks
Scott
Yes there is a lower seal/cup.
I don't think you can buy this separately.(Comes with the lower bearing from Yamaha)
I fitted this complete kit to my 2011 660z
http://www.ebay.co.uk/itm/ALL-BALLS-STE ... SwQItUGvVz
Maybe of some help.
http://www.xt660.com/showthread.php?t=17320
2011 Yamaha XT660Z Tenere
scottnet
Post by scottnet » Sun Jan 24, 2016 3:58 pm
Thanks, a couple of q's
1) did this kit you bought have the lower seal ?
2) Or did you manage to get the lower bearing of with out damaging the seal ?
3) How did you get the lower race out of the frame, I have the top one out ok but the lower I cant a grip on the edge to drift out I have applied heat, next step is to cut it out
Gary117
Post by Gary117 » Sun Jan 24, 2016 4:04 pm
scottnet wrote:Thanks, a couple of q's
1/ Yes.
2/ No i damaged the seal removing the lower bearing.
3/ I have one of these. http://www.ebay.co.uk/itm/Sealey-MS040- ... Sw42JWC~Xx
scottnet
Post by scottnet » Sun Jan 24, 2016 4:09 pm
Thanks for the info. The removal tool looks good
daryl
Has thanked: 4 times
Been thanked: 24 times
Post by daryl » Sun Jan 24, 2016 4:17 pm
Tool wise, I'd recommend something like this:
Took all of about 3 taps to remove each race on my 690.
Gary117
Post by Gary117 » Sun Jan 24, 2016 4:18 pm
scottnet wrote:Thanks for the info. The removal tool looks good
Yes makes the job a lot easier.
I'm in Cheshire so if your local your more than welcome to borrow it.
The bearing on the stearing stem was very tight to get off so i used a dremel
scottnet
Post by scottnet » Sun Jan 24, 2016 4:22 pm
Gary thanks for the offer but i am down south.
Is there a tool for getting the new bearing on the stem?
daryl
Post by daryl » Sun Jan 24, 2016 4:24 pm
scottnet wrote:Gary thanks for the offer but i am down south.
I've always used what's left of the old bearing, a bit of pipe, and a hammer.
Gary117
Post by Gary117 » Sun Jan 24, 2016 4:27 pm
Like daryl.
I used the old lower bearing upside down and a tube.
Users browsing this forum: chunky butt, macvisual and 34 guests
