Fuel tank ranges?
Re: Fuel tank ranges?
R1100GS about 220 but down to 200 if I'm being a pillock.
I used to get 50 out of my KTM200exc too but have just gone back to standard gearing (14-45) and it's up to around 75 ish now. It's not helped by the fact that I spend a lot of time on my arse or picking it up and they just love to be thrashed!!
Also got an Enfield 500T and that will do around 200 to the tank but that's less than 13 litres to reserve. Unfortunately never seems to run long enough to drain the tank but I do love it:P !
I've done 300 miles before switching to reserve on my TTR600, so probably could go 340ish. Not bad for a 20 litre tank, it's a frugal single and I'm not ashamed to admit that I ride like an old lady when the mood takes me.
A ship is safe in harbour, but that’s not what ships are for. – Grace Hopper
- OB1
- Has thanked: 746 times
- Been thanked: 342 times
I've had around 220 miles from the Tiger XC's tank on a long run but generally I get around 180 miles with the light coming on at 145ish.
justrtw.com
justrtw.com
- Has thanked: 13 times
- Been thanked: 110 times
1200 GSA you get no more than 280/290 when caning her (85/90mph) or well over 320/340 when pootling...!!
I usually get 180ish from my lovely Bandit before the last bar starts flashing but I'd probably get more if I didn't practice my drag starts at all the lights and so on (need to practice for the Bulldog Bash RWYB).
Its a Bandit, that's what you're meant to ride them like. :S
I always use this site to periodically calculate my exact MPG on my bikes and cars....
http://www.which.co.uk/cars/driving/dri ... alculator/
I always set my trip meter to zero whenever the reserve light comes on, then put in usually £15 or £20 of fuel depending on if its the car or bike. Then take the trip mileage when the fuel light comes on again and put the figure in this calculator. This will give you your exact MPG.
My Bandit 1250 never seems to go outside 45 - 48 MPG and it does get thrashed occasionally. But my Wee Strom's MPG can vary quite a lot between 50 - 62 MPG depending on how its ridden.
I'd be suspicious of that method, mainly because I know the point at which the fuel gauge starts flashing on my Tenere is incredibly variable. Other bikes may have less rubbish gauges, but I generally just brim the tank with the bike upright on level ground, reset the trip counter, use most of the tank then see how much it takes to brim it full again. I don't think the capacity of the tank changes significantly between fill-ups, but I know the fuel gauge doesZookman wrote: I always set my trip meter to zero whenever the reserve light comes on, then put in usually £15 or £20 of fuel depending on if its the car or bike. Then take the trip mileage when the fuel light comes on again and put the figure in this calculator. This will give you your exact MPG.
Somewhere bestween 155 miles to +225 miles depending on how nice I ride and also different with luggage and wife than without.
Niklas
Niklas
