Just received these 2 of these bad boys today on the post. Still need to sort bracket, wiring loom and switch! Any suggestions? Anyone has any of the above for sale?
Thanks
BMW F650/800GS Spot Lights
rodrigoscs
- Has thanked: 13 times
- Been thanked: 4 times
vRSG60
- Has thanked: 68 times
- Been thanked: 94 times
Re: BMW F650/800GS Spot Lights
You can buy a waterproof loom/switch/relay assembly on Ebay/Amazon.
I mounted my Givi Fogs on the Engine bar of my F650GS. Quite low down.
rodrigoscs
Thanks. I've also been watching that switch. It's probably what I'm going for.
Regarding mounting the lights so low it would not work for me, as they would be very exposed for the kind of riding I do. I also like to make use of the crash bars occasionally!
I'll need something like this: http://www.ctmotorcycleservices.co.uk/p ... unting-bar
Diesel Pete
If it helps, I bought one of those switches in May and have since done nearly 6000 miles through all kinds of weather and it has been perfect. I also used cheap lights and mounted them on the crash bars and they too have been "spot" on (thumbs)vRSG60 wrote:You can buy a waterproof loom/switch/relay assembly on Ebay/Amazon.
I'm probably a bit simple, but what's the need for the relay?
I was just going to run a wire from the battery to the lights in parallel with a fuse and switch in-line :unsure:
APD_660Ten
Not an expert but I believe the idea is that you wire it straight to the battery and the relay stops any current draw unless the ignition is on. A switch will work straight to the battery but you can forget to switch it off. You could wire it to the existing light circuit but you 'could' overload it.
Does that wiring/switch kit include the relay shown in the diagram?vRSG60 wrote:You can buy a waterproof loom/switch/relay assembly on Ebay/Amazon.
vRSG60
It looks like it to me. There's a relay in the photograph of the wring & switch bundle.Pingman wrote:
The Givi lights come with a wiring loom that includes a switch, fuse & relay so I haven't used the Amazon switch.
R and G racing do the Denali bracket that locates them just below the beak, i bought it recently and looks really good.
You do need to check the year to see whether it fits but for 40 quid its eactly what i wanted!
