**Salisbury Plain Rally 2015** 21st 22nd 23rd August 2015
Re: **Salisbury Plain Rally 2015** 21st 22nd 23rd August 2015
Actually the route is not that long..my TYRE thingy says it is but I think it's messing up somewhere. Last years was 90 end to end and this years is not much longer.
Mike
Mike
Here are the easy ride AM and PM routes.
Mike
Mike
- PMSalisburyRallyeasyride.gpx
- (347.36 KiB) Downloaded 39 times
- AMSalisburyRallyeasyride.gpx
- (321.8 KiB) Downloaded 41 times
I got up THAT hill on Sunday on the 690 with a shitty rear tyre Mike. It'll be fine as long as it ain't rainingMike101 wrote:With the exception of one uphill bit I've ridden all the route on my 950 and it's all fine.....I can't get my 950 up the steep bit so we'll see how you are get on!
(Dropped into The Lamb for lunch too)
Oh you should have let me know as I was in at home all day.~ACP~ wrote:I got up THAT hill on Sunday on the 690 with a shitty rear tyre Mike. It'll be fine as long as it ain't rainingMike101 wrote:With the exception of one uphill bit I've ridden all the route on my 950 and it's all fine.....I can't get my 950 up the steep bit so we'll see how you are get on!![]()
Mike
- Been thanked: 4 times
200 miles on my 2stroke in a day will be pushing it. I don't think I would be able to feel the lower half of my body. I have a few routes which I have done with russ on my gps and can sort something fun out.
It's not that far...my Nav thingy messed up..trust me..you will have fun.phil.hughes1983 wrote:200 miles on my 2stroke in a day will be pushing it. I don't think I would be able to feel the lower half of my body. I have a few routes which I have done with russ on my gps and can sort something fun out.
Mike
Why are the track and the route within the gpx different? The track appears to go up and back on itself a few times.Mike101 wrote:Here are the GPX files for the hard ride. Please can somebody upload them and check them out. They are created on TYRE using google earth but should be fine for people to follow as a set of waypoints.
Mike
Anybody else found this?
- Has thanked: 18 times
- Been thanked: 19 times
Yeah, I found that when I opened it on Basecamp.MHsnowy wrote:Why are the track and the route within the gpx different? The track appears to go up and back on itself a few times.Mike101 wrote:Here are the GPX files for the hard ride. Please can somebody upload them and check them out. They are created on TYRE using google earth but should be fine for people to follow as a set of waypoints.
Mike
I just ignored the track and put the route onto my Montana by itself (as a track), seemed to work ok - insomuch as it shows a clear route on the map with no little dead-end branches leading off here and there as before. (thumbs)
Assume this will also be the case when I come to use it...then again, might have completely cocked it up - not the most computer/sat nav savvy... :whistle:
Ive done a more accurate track following the route more closely using Garmin GB discoverer. Can you have a quick look Mike101 and see if it's right?
Cheers for lookng at this. I created it on TYRE and i think it took the waypoints and then created a route using as many as roads to get to each waypoint as possible..thats why it's over 200 miles long on the route...it's more like 100 miles long in total.MHsnowy wrote:Ive done a more accurate track following the route more closely using Garmin GB discoverer. Can you have a quick look Mike101 and see if it's right?
if you go from one waypoint to the next in order you will all be fine...i hope..if not the plain's not that big for you to get lost on.
Mike
Return to “Salisbury Plain Rally 2015** 21st 22nd 23rd August 2015”
Users browsing this forum: No registered users and 1 guest
