12v attachment advice please
markyt
Post by markyt »
Can someone help me with this. I have a terminal at the front of my bike(like the photo) which is hard wired in (not direct to battery) and its for an optimiser. My question is could i just plug a 12v cigarette lighter attachment point into this (that has a fuse)so I can run a 12v point on my handle bar or will i have some sort of elecrical issue.
cheers
AndyB
Re: 12v attachment advice please
Post by AndyB »
The simple answer is yes but you need to use a good quality accessory plug because it'll be permanently live and may not like it if rain pours in :dry:
leo-david
Post by leo-david »
Optimate do a 12V socket attachment that plugs straight into that socket.
http://www.optimate.co.uk/tm68.htm
Bought one myself at the bike show, think it was about £10.
onslowe
Has thanked: 41 times
Been thanked: 36 times
Post by onslowe »
I also fitted the same set up using the Optimiser socket, not 100% waterproof so careful where you fit it. I have mine for temporary use so can remove quickly or unplug if things are too wet, OK for mobile phone backup charger etc. Not many of these are waterproof when a socket is installed anyway so its a decent compromise solution.
Regards,
Martin
Dark Knight
Been thanked: 99 times
Post by Dark Knight »
Must admit that I do not find those optimiser plugs/sockets very reliable as the socket contacts tend to bend and go open circuit.
I personal would use a better quality plug and socket.
bowser
Post by bowser »
I have used that same style of plug to connect up all sorts of things, compresser, tent light, sat nav.
But the comments here are valid they corrode easily and the pins get broken.
I find the better solution is to use the Hella/BMW/KTM DIN type plug where it clicks into place it has a waterproof cover and is a positive secure fit as opposed to cig lighter style, I have leads that then connect to the optimate, or a standard cig socket and all the accessories I use now have the Hella plugs or the ones with the removeable red ring so you can use them in both types of socket
http://www.clasohlson.com/uk/36-3904?gc ... tAodcjsA8w
adventuredon
Post by adventuredon »
have used these exact couplings to connect my sat nav for over a year and had absolutely no problems. And it stands outside all year!
john_aero
Been thanked: 3 times
Post by john_aero »
Ebay ebay
I just got 2 12v sockets with usb inserts fot £7 delivered thrb either wire to batt ot wire to switched power
QuickNick
Has thanked: 3 times
Post by QuickNick »
john_aero wrote:Ebay ebay
Have you got a link to that please?
Road2Manchester
Post by Road2Manchester »
I sell these on Ebay
£8,95 incld postage.
http://www.ebay.co.uk/itm/331123324202? ... 1555.l2649
cam to gif
If you ride like the wind, expect to get blown away. One lifetime is all we get use it wisely this ain;t no practise.
