BMW DIN adaptor advice
P4ulie
Has thanked: 45 times
Been thanked: 81 times
Post by P4ulie »
I'm wondering what you guys use. I want an adaptor from normal cigarette charger to BMW / Triumph DIN.
Something like this one
I don't want an extra lead as the charge point is on the dash itself & because I will change sat nav / phone charger between bikes don't want to faff wiring in adaptors. This is ideal but at £12 + £3.50 postage not exactly a bargain. I've had a look on fleabay but obviously putting in the wrong search criteria as can't find similar :(
Any ideas?
Ta muchly
VR_Rider
Re: BMW DIN adaptor advice
Post by VR_Rider »
P4ulie wrote:I'm wondering what you guys use. I want an adaptor from normal cigarette charger to BMW / Triumph DIN.
Any ideas?
Ta muchly
You can just get the ding socket plug which you can than chop of the standard cig socket attachment and wire in. Obviously this is only ok if you know how to do it, and only want to use the item on the bike.
We sell them at the BM deaeler I work for on sundays, I'll see if I can get a part number so you can see if you can get them cheaper someowhere.
sparks
Post by sparks »
Pm sent
Adam
davsato
Been thanked: 4 times
Post by davsato »
vehiclewiringproducts.co.uk do a good selection, you could put a full sized cigarette socket extension inside your top box, then you can charge what you like in the dry
Dave
Return to “ACCESSORIES”
