wilky wrote:I Will look at getting a Dakar Shock and putting it on and will see if i can get some new forks(or just put new springs in)
Not looking to do major off roading but want to take it and play
any suggestions on what forks?
depends on whether you are going to fit a bigger wheel?
if you defo want a 21" my advise would be to source a complete front end,the cheapest option would be to use a WP setup from a ktm or maybe a Yamaha 425 ,off ebay ,and start with that.
if you want to stick with stock yokes etc a g/s650 or Dakar set will fit straight in,but you will lose the speedo drive.
if you are going to stick with the stock forks and 19" wheel (just returning to stock ride height) you really don't want to fit a Dakar shock as it really will mess the handling,the front will be like a shopping trolley ,with no grip. :laugh: :laugh:
so both ends need to be done at the same time.you would gain about 4" more ground clearance.
if you mod the footrests as well.fit some decent rubber it will get through this no bother :laugh:
- P1011379_2013-12-14.JPG (80.32 KiB) Viewed 1782 times
a standard 650 would have been stopped twenty feet into this lane
