What a cracking weekend we had.
Gribbs
Re: What a cracking weekend we had.
Post by Gribbs »
CRAIGREVO wrote:
Gribbs wrote:
CRAIGREVO wrote:
Gribbs wrote:i will call them tomoz to send some of them back. the guy who was helping was thick. he showed me a blow up diagram of the gear assemble and i pointed out what i needed, but he didn't have a clue how to order the individual parts. i will speak to Carl if he is in. he knows what he's on about
It should be just the mounting plate you need unless it all comes as one peace. ;)
I have had a look at it and i will need the plate and a ball joint lever were Bear Grills (my hero) welded a new lever to. everything else is salvagable:silly:
will speak to drayton croft to send back the bits i dont need :side:
I can grind the weld off the lever for you.
Na, its missing the ball joint that you screw the puss rod into. should only be a couple of quid for that anyway
