Tev did the work myself very simple engine ,,,,, Henry Price supplied the exchange crank (with a steel rod roller bearings and balanced , i used Henrys special cams as well ,
john
- Has thanked: 200 times
- Been thanked: 182 times
No one else confessing to buying one ? Had mine a week and so far so good , engine is nice and smooth . Not a bike to play "spec sheet Top Trumps" with but seems to do what I wanted . Looked at the CRF Rally as an option and it's probably (definitely ?!) a better bike but it was the Himalayan I wanted
- himafrrhs.jpg (234.54 KiB) Viewed 4606 times
- Has thanked: 1178 times
- Been thanked: 727 times
https://www.facebook.com/Nathan-Millwar ... 829160127/
Nathan has one and seems very pleased with it : )
Suzuki DR200 Djebel.
Hard to compare with what I've had before, I've had a lot of bikes ,50+ , but I took a demo ride before buying - which I've never managed on any other new bike and so was able to remove my concern about the low BHP. Compared with most singles it's a very smooth/tractable motor with none of the usual chain clatter you get at low revs . Suspension is adequate , no adjustment except rear pre load , damps fine and feels well matched . If you want a bike for sustained motorway use , "hard" trails Welsh bogs/rock steps etc , third gear wheelies (or any wheelies!) it's patently not the right bike . But for what I think I want atm , a bike to do local rides , trails , maybe a European trip and light touring I think it seems right .
No glossy plastics , comes with rear rack , centre stand and a bit flimsy but not plastic sumpguard and is a bit different , sold !
Yep , I much agree with everything he said on hereBrenhden wrote: ↑Wed Feb 07, 2018 1:23 pm https://www.facebook.com/Nathan-Millwar ... 829160127/
Sorry silly question really but thanks for giving it a go ; ) Sounds like you're well pleased. I have a 2008 RE efi and really love getting out around the back lanes especially in the Winter, the Himalayan would allow me to tackle some gentle trails as well but it won't have the same character as the efi (probably a good thing in most cases) so not sure I want to swap that one out, more like a replacement for my Africa TwinBojer wrote: ↑Wed Feb 07, 2018 1:55 pmHard to compare with what I've had before, I've had a lot of bikes ,50+ , but I took a demo ride before buying - which I've never managed on any other new bike and so was able to remove my concern about the low BHP. Compared with most singles it's a very smooth/tractable motor with none of the usual chain clatter you get at low revs . Suspension is adequate , no adjustment except rear pre load , damps fine and feels well matched . If you want a bike for sustained motorway use , "hard" trails Welsh bogs/rock steps etc , third gear wheelies (or any wheelies!) it's patently not the right bike . But for what I think I want atm , a bike to do local rides , trails , maybe a European trip and light touring I think it seems right .
Yep , I've had a 350 and 500T Royal Enfields before so didn't have too high expectations !
Not quite the same "thump" as the 500 but not far off and at least as "fast" , exactly as you say for winter back lanes , and a few trails it's like the perfect bike . I was a bit concerned at the 24 BHP , not that I needed more but the demo ride made me appreciate its torquey feel means the power not so relevant . Highly recommend a test ride - if only to rule it out , the bike I took out only had 60 miles on it so took it easy but I liked the feel of it.
I've only done 200 odd miles in the week so early days as I said but pleased with it , downsides are a "weak" front brake , it works but doesn't suggest ABS is necessary ! , have ordered some EBC HH pads to see it they'll improve things and a slightly random fuel gauge that sometimes dives for empty before recovering a few minutes later - dodgy sender/wiring , due to be looked at when it gets its first service . .
- Has thanked: 207 times
- Been thanked: 92 times
Shocking!ds99 wrote: ↑Mon Mar 27, 2017 8:57 am maybe read this before buying one!
https://www.rushlane.com/royal-enfield- ... 37993.html
