WK400 owners thread.
Tyrant68
Has thanked: 56 times
Been thanked: 52 times
Re: WK400 owners thread.
Post by Tyrant68 »
garyboy wrote:O dear.!! .. trim the throttle grip so it returns freely. OR..
Perhaps the RHS bolt for holding on the RHS hand protector needs pulling out 10 mm ? then re-tightening.
It was tight without bolt put back in.
Trim? A bit off the end?
garyboy
Has thanked: 2418 times
Been thanked: 1041 times
Post by garyboy »
Sounds like it needs trimming. A sharp knife or Stanley knife will do it. But check if there is another way first.
Yes. The outside end.
garyboy
Post by garyboy »
i did mine last week? for the crf250l and I had to both trim the outer end of the heated grips I was fitting AND
pull out the handguards by 10 mm ... held it there in the place I wanted and then tightened the bolt.
it is very important to have free movement.
Andi_Archer
Has thanked: 3 times
Been thanked: 126 times
Post by Andi_Archer »
From the WK Facebook page
netsonic
Has thanked: 14 times
Been thanked: 49 times
Post by netsonic »
Interesting news on the WK400 return later this year........on a side note anyone tried new front brake pads in theirs to improve brake bite, if so what make and compound did you go for, its something i am thinking of trying but thought i would ask if anyone has already given it a try
Andi_Archer
Maybe you could retro fit a larger caliper onto the disk to give more leverage?
Glenn_G
Been thanked: 7 times
Post by Glenn_G »
Cheers Andi - good news about a euro 4 bike out later.
Netsonic - Mine also need changing asap and I'm looking at these fa465 pads :
Either cheaper semi metallic :
http://www.ebay.co.uk/itm/401142715837? ... EBIDX%3AIT
But will probably try these next :
http://www.ebay.co.uk/itm/351859517789? ... EBIDX%3AIT
Andi_Archer
Andi_Archer
Just be aware a harsher pad will put more wear on the disk B)
Tink
Has thanked: 657 times
Been thanked: 214 times
Post by Tink »
This advert says bikes in stock, thought there were none left :dry:
http://lancastermotorcycles.co.uk/product/wk-400-trial/
