So who has bits of metal screwed in them?
macdee
Re: So who has bits of metal screwed in them?
Post by macdee »
I have broken my left femur,pelvis left arm
Shoulder in one crash
The plates pins screws are great at getting you back into closest position as you were before your accident
As it close to you joint it also helps to reduce the chances of arthritis
I had my metal remove about 18 months after the crash as they did give a lot of pain due to constant Rubbing of the soft tissue
For long term results I would go for metal work all the time
Do the best you can to minimise the chance of infection from your open wound an in good time get stuck into physio
My wife had a similar break as yourself last year and the 6" plate and 9 screws need to come out as it is causing to much pain
But on the upside the surgery was a great success
I have seen the X-ray and the bone was set perfectly
Good luck with your op
Mosel Bikes
Has thanked: 129 times
Been thanked: 80 times
Post by Mosel Bikes »
currently sat, 1 week post op for surgery to my left shoulder, following a fall whilst walking the dogs that severed the ligaments connecting the shoulder and collar bones. was in hospital three nights. they opened and then wired in a figure-of-eight. i've also got a titanium hip replacement, stents in the heart and a silicone and metal scleral buckle round my left eye, following a detached retina.
with the 'major'hip op, i went in and under at 2,30 on tuesday and was home 25 hours later (northumberland fast-track scheme), was walking without sticks in a week and driving a week after that. this shoulder injury,though seemingly less serious (?) is far, far worse.Constant pain,no pain killers even touch the pain (even iv andinjections) and I can't use my arm (hence typing!). early physio is a killer.
points are, each person/injury/recovery is different. I looked at a lot of videos on youtube, where most people/places take it steady, with gradual physio and a sling to support for 8 weeks minimum. in germany, they started physio on day one and told me not to use a sling! It's killing me to be honest, never had pain like this - we're talking 'just leave the bottle, then bring me a gun after half-an-hour'!
So, no idea what the long term will be for biking. right now, this moment, i don't give a monkey's, and just want the pain to ease.
good luck with it whatever happens.
Greyhound Racing .... don't bet, don't go - you bet, they die :cry:
sprintster
Has thanked: 105 times
Been thanked: 71 times
Post by sprintster »
I went over the handlebars of my motorbike 38 years ago and it landed on my shin.I've now got a steel plate and three screws.I was told at the time that they would probably come out later if it started to cause problems but it has never affected me unless I bang my shin against something and hit a screw,then it hurts.
Keep up the physio.I was hobbling around on crutches all the time I had a full leg cast on but even then when the cast came off my leg was just skin and bone.
big al
Been thanked: 48 times
Post by big al »
Broke my neck 30 years ago, got three wedges from c2 to c5 in my vertebrae, went through my throat to access said break left me with loss of feeling in right hand and fingers, and a constant feeling of a sweet stuck in my throat, needing to swallow constantly. Then if that wasn't enough had a car crash on pontabraham roundabout 15 years ago at the end of the M4 ended up me cracking c6 and a blood clot around c3, c4 stuck in hospital for 12 weeks waiting for crack to heal and clot to disperse.
and the buggers even cut the roof off my cavalier and made it into a convertible :whistle: .
but hey back on bikes.
Happy days, and my pal up stairs still loves me. Apparently I've still got eight left. (thumbs)
Al
reedro72
Has thanked: 4 times
Post by reedro72 »
Sitting with a broken fibula now , happened out riding last fri 11am trail riding mate didn't see me turning right and run into me , took boot off and gaffer taped tight from ankle to knee as could stand on it and rode rest of day until 4 was sore but not un rideable , went X-ray at hospital and fibula broken 6 inches up from ankle , surgeon offered me pins or let it heal , I opted for letting it heal as had a mate that had infection in his , have been up to the physiotherapy center in Ipswich this week and had 3 back to back sessions of pulse magnetic therapy and laser on it as recommended by a few mates and now awaiting further X-rays in 2 weeks time , not allowed to weight bare on it , anybody else had it done with any success ?.
Nick
Paul_C
Has thanked: 1374 times
Been thanked: 1331 times
Post by Paul_C »
Plate just above my right wrist thanks to a SMIDSY. Shattered, then had removed, the head of my left radius. Somewhat bizarre accident playing squash when I managed to turn my arm into a telescope. Yes, we can manage without that bit.
Many, many tooth fillings too but I guess they don't count.
Just along for the ride.
Tyrant68
Has thanked: 56 times
Been thanked: 52 times
Post by Tyrant68 »
Came off the bike and dislocated my shoulder 4 years ago. Tore the Supraspinitus and infraspinatus off the rotator cuff, Hills sachs lesion on the humerous, fractured the humerous and elbow, tore the long head bicep off (couldn't repair) and have a Glenoid like crazy paving . Everything held together with expensive binder twine and peak inserts.
Now 50% less strength on dominant side
Last year I had a Total Knee Replacement. Suffered with OA for years then an accident at work properly destroyed it so was told not to return until I had had the TKR (HR dep were superb)
No longer have an ACL , and a lax outer LCL which can make for epic fails when it occasionally buckles (usually a head butt on the cross trainer :laugh: ) which allows the knee to unhinge too far and hit the fibula head and disturbs the peronaeal nerve (still can't walk downstairs normally )but getting stronger
lancashirelad
Has thanked: 201 times
Been thanked: 273 times
Post by lancashirelad »
Bloody hell we'll be able to weigh some of you buggers in for scrap when the time comes!!!
Tyrant68
Post by Tyrant68 »
lancashirelad wrote:Bloody hell we'll be able to weigh some of you buggers in for scrap when the time comes!!!
:laugh:
I nearly spat my coffee out reading that :laugh:
Nigel
Has thanked: 189 times
Been thanked: 102 times
Post by Nigel »
19 years ago compound fracture of Tib and broken Fib, 5 months with external fixator and three different plasters over the next 5 months, actually I could feel where the tib broke when I was walking about today :huh:
Picos mountains, on MTB, head on into the front of a 4x4, combined impact speed of 40+ mph :sick: busted wrist and dent in top tube of bike frame where the bars whipped round and impacted wrist into frame, big dent in bonnet of 4x4 when my head impacted and a bloody good headache :laugh:
Return to “THE PUB”
