Tesco's 10w-40 oil query
- Has thanked: 754 times
- Been thanked: 632 times
Was in my local Tesco's store this morning, I found they have on offer; 10w-40 motor oil Part-Synthetic, suitable for petrol & diesel engines, meets requirements of the following:
API SN/CF, ACEA/B3, A3/B4, MB 229.I
Cost is £8 for 4 litres.
So, the question is? Could I use this oil for my Suzuki DL1000 V-Strom motorcycle I wonder..??
I'm sure Part-Synthetic means the same as Semi-Synthetic...?
My Suzuki owners manual states to use; 10w-40 API SF or SG, or SH, or SJ
Cheers;
Peter
Cheers;
Peter
Frank Zappa
Frank Zappa
- Has thanked: 14 times
- Been thanked: 55 times
Re: Tesco's 10w-40 oil query
Assuming your clutch is a wet clutch you will probably need to check if it's JASO MA compatible, otherwise you are likely to experience clutch slip.
Current bikes: XT1200ZE, MT01, XV750se, TRS 300RR, Scorpa factory 300- still mine despite some thieving scum bag bastard currently having possession of it
- Steve T
- Has thanked: 260 times
- Been thanked: 841 times
It's car oil, so no good in a wet clutch motorcycle.
Steve T
Steve T
ZEN DOG
- Has thanked: 1414 times
- Been thanked: 1669 times
As above...it contains friction reducers and may harm your (wet) clutch.
I buggered the clutch on my GasGas by using a Synthetic oil, which made the friction plates swell up. Had to fit a complete new clutch pack.
- Has thanked: 367 times
- Been thanked: 108 times
I was told to use ATF in the gas gas trials bike but then others said use light gear oil SAE 80Richard Simpson Mark II wrote: ↑Mon Sep 02, 2019 4:58 pm As above...it contains friction reducers and may harm your (wet) clutch.
- Has thanked: 2 times
- Been thanked: 84 times
I've used cheap car oil in my xt660z once the mileage got high and I stopped worrying about it. 104k in and no clutch slip. Used car stuff in old gsxr too and no clutch slip 57k on clock.
Yamaha tenere 700
I suffered unpredictable clutch action with my Pampera for years. Difficult to set up without drag or slip...and it's meant to be self-adjusting.frenchy3 wrote: ↑Mon Sep 02, 2019 5:06 pmI was told to use ATF in the gas gas trials bike but then others said use light gear oil SAE 80Richard Simpson Mark II wrote: ↑Mon Sep 02, 2019 4:58 pm As above...it contains friction reducers and may harm your (wet) clutch.
then I stumbled across an American You tube, hosted by the former service manager of Gas Gas USA.
Recommended 5W-30 mineral oil car engine: which I found at an American car specialist.
Seems OK so far.
