eBikes next
Has thanked: 2280 times
Been thanked: 992 times
Re: eBikes next
Post by garyboy »
DaveCon wrote: Thu Jul 25, 2019 12:44 pm
I think your battery needs a couple of discharge/charge cycles before you get the full benefit.
I was wondering this
as it came on line after half discharged
Redmurty
Has thanked: 337 times
Been thanked: 153 times
Re: eBikes next
Post by Redmurty »
garyboy wrote: Thu Jul 25, 2019 1:32 pm
batteries come in "hibernation" mode was it fully charged before going out, it took me hours to charge mine the first time as I had switched the charger on properly :oops:
cheers Spud ;)
Re: eBikes next
Post by garyboy »
The guy on the shop said it was fully charged and the battery indicator bars were showing full
He said he had tested the bike in the car park and everything was ok
But shortly into my epic ride home (first time for decades) I could see something was wrong .
But seems to be getting better?
Has thanked: 330 times
Been thanked: 634 times
Re: eBikes next
Post by Tramp »
What you have to remember is lithium batterys have a memory so need discharging then full charge then run down... Continually halfi charges buggers them up...
DaveCon
Has thanked: 102 times
Been thanked: 100 times
Re: eBikes next
Post by DaveCon »
Tramp wrote: Fri Jul 26, 2019 8:25 am What you have to remember is lithium batterys have a memory so need discharging then full charge then run down... Continually halfi charges buggers them up...
Oooooh not sure that's right :?:
The old NiCAD batteries needed a full discharge before you charge them up again. Continually charging them before they were empty meant they would eventually only partially discharge before packing up.
Lithium batteries are different. They can be charged at any point without suffering but if you let them discharge beyond a certain point, they are unrecoverable. The software in your device will stop using the battery before it reaches this point. However if you leave a partially discharged battery on a shelf, the charge will decay on its own and eventually go beyond the point of recovery. At £500ish a pop you don't want that happening
That's why the mantra is "finish your ride - charge your battery". Don't leave it sat there with less than 80% charge. ;)
Oop North John
Has thanked: 154 times
Been thanked: 199 times
Re: eBikes next
Post by Oop North John »
DaveCon wrote: Fri Jul 26, 2019 9:15 am
I think that you're right about the nicad batteries 👍
Cone
Has thanked: 156 times
Been thanked: 252 times
Re: eBikes next
Post by Cone »
garyboy wrote: Fri Jul 26, 2019 8:11 am The guy on the shop said it was fully charged and the battery indicator bars were showing full
You weren’t trying to ride over 15mph were you as you know the EU won’t permit that
Re: eBikes next
Post by Tramp »
Always happy to be educated lol :oops:
Re: eBikes next
Post by garyboy »
DaveCon .. "That's why the mantra is "finish your ride - charge your battery". Don't leave it sat there with less than 80% charge"
:shock: :shock: :shock: o right !! 8-)
Cone .. "You weren’t trying to ride over 15mph were you as you know the EU won’t permit that
:lol: :lol: :lol: I ve had a word with mr. junker … so I should be ok for a few days?
Return to “THE PUB”
