Yamaha XT660z Tenere
mark vb
Has thanked: 329 times
Been thanked: 695 times
Re: Question for Yamaha XT660z Tenere owners
Post by mark vb »
Chris S wrote:XTZ request
Would a 660Z owner mind measuring the inside distance between the front rotors for me? Ta.
It's approx. 107.2mm.
Incidentally, Amazon is out of stock of Street Riding Years....can it be bought anyplace else?
Chris S
Has thanked: 88 times
Been thanked: 210 times
Re: Yamaha XT660z Tenere
Post by Chris S »
Thanks for that, Mark.
SRY paperback should be back on amazon now.
Or paypal me 8.99 and I'll post for free.
I've PM'd you the email.
stevieboyle60
Post by stevieboyle60 »
Just bought xt660z 0n a 63 plate is your dipped beam meant to go out when you go on to full beamImage
Sent from my SM-A202F using Tapatalk
cozi70
Has thanked: 32 times
Been thanked: 91 times
Post by cozi70 »
stevieboyle60 wrote: Fri Mar 06, 2020 7:54 pm Just bought xt660z 0n a 63 plate is your dipped beam meant to go out when you go on to full beamImage
Yes,but there is a wiring mod you can do so both stay on together. Unfortunately I read it on the now closed xt660.com forum but someone should know.
I never modified mine as I'm always planning to fit driving lamps 🙄
stevieboyle60
I never modified mine as I'm always planning to fit driving lamps Image
Ok thanks though there was a problem with wiring
Ok thanks thought there was a problem with they wiring
cozi70
Post by cozi70 »
You'll notice you can keep the dip beam on and activate the high beam via the pass/flash switch simultaneously to see if it is worth doing the modification.
Has thanked: 330 times
Been thanked: 634 times
Post by Tramp »
Steve Boyle.... If you haven't done so the xt660z Facebook page is excellent over 10,000 folks worldwide now
... Its taken over from the old defunkt xt660. Com forum
And mines black and dirty..
stevieboyle60
cozi70 wrote:You'll notice you can keep the dip beam on and activate the high beam via the pass/flash switch simultaneously to see if it is worth doing the modification.
Thanks again guys this is helpful
stevieboyle60
Does anyone know do I have to buy a back plate fit a back box bought a universal lextech at mcm ingilston yesterday don't think its going to fit
cozi70
Post by cozi70 »
My previous owner made his own, using the rear grab handles holes and the rear most subframe holes, beside the rear plastic or latch.
Sheet of alloy plate,4 spacers,4 countersunk bolts.
Those extra holes in it are just for attaching a dry bag when not using the top box.
