Tyres + Inner Tubes for XT660Z - What do you recommend ???
Kinioo
Post by Kinioo »
Hi all,
I am after new set of tyres plus inner tubes for my Tenere XT660Z (2011 non ABS model).
Mainly on-road use.
What do you recommend guys ??
Cheers,
Chris
qcnr
Has thanked: 695 times
Been thanked: 243 times
Re: Tyres + Inner Tubes for XT660Z - What do you recommend ???
Post by qcnr »
Something that is of the correct size is always a good start.
AlanHolt
Has thanked: 382 times
Been thanked: 398 times
Post by AlanHolt »
I guess it depends on what the off-road consists of. If it's a dry track, something like the Michelin Sirac would be good as they are great on-road. They do struggle when the ground becomes wet though.
Current bike is a Yamaha T7
Kinioo
Post by Kinioo »
qcnr wrote:Something that is of the correct size is always a good start.
Really? What is the correct size - yours or mine ??
crofty
Has thanked: 205 times
Been thanked: 156 times
Post by crofty »
Just back after a great day out on mine. its shod with Anakee 3s
,good road tyre.
Mike101
Post by Mike101 »
K60 scout is all you will ever need.
Mike
And the beast shall be huge and black, and the eyes thereof red with the blood of living creatures, and the whore of Babylon shall ride forth on a three-headed serpent, and throughout the lands, there'll be a great rubbing of parts
robson
Post by robson »
for road use? stick with the stock tyres. They're good enough,
but if you wanna look better, get tkc80. Don't ride too fast in rain though.
halfpint
Been thanked: 52 times
Post by halfpint »
Mefo are good on road and a bit of off road.
WIBO
Has thanked: 612 times
Been thanked: 648 times
Post by WIBO »
Kinioo wrote:Hi all,
Mainly on-road use.
Cheers,
Chris
Morn'in... :)
You say mainly road which suggests the odd excursion off road here and there?
What works for me....I'm on my fifth set of Mitas EO7's..... 140x80 on the rear and standard on the front....I ride mixed but mostly on dry hard pack.
The reason I'm still on these tyres is that they're cheap,I get lots of kms out of them,they're hard wearing on hardpack/rock and they're really good in both dry and wet fast riding on the twisties here..really good; they just don't look like they should be :)
They can just about cope with some damp ground.
(As an aside, on two separate trips to Morocco,with two other riders on a TTR600 and an XTZ660 and following the same hard pack trails ,their K60 Scouts came back quite cut up whereas the E07's were unscathed...hence my return to this tyre each time I need a change ..one of the riders returned the next year and replaced with E07's )
Just my two cents...
All the best
Will It Buff Out?
XTChris
Post by XTChris »
I have always used Mitas E07's on my Tenere. I have found that I get two rears to every front. For about £100 a pair you cant go wrong.
They aren't the greatest in the sloppy stuff but will get you through.
