The Suzuki DR thread.
Has thanked: 330 times
Been thanked: 634 times
Re: The Suzuki DR thread.
Post by Tramp »
There are 2 seals one on the adjuster screw a paper thingy and another between body and head...clean surfaces ......bolts are NOT done up tight just nipped ie 10nm...
http://www.thumpertalk.com/topic/613297 ... sket-leak/
Brenhden
Has thanked: 1177 times
Been thanked: 727 times
Post by Brenhden »
Done, if I could add a piece of advice it would be to wind it in before removal, you can get it out of the area much easier that way.
Poor thing hasn't been ridden enough lately, had to charge the battery :(
motorbike
Has thanked: 6 times
Been thanked: 29 times
Post by motorbike »
there is a nice wee 350 for same on gumtree just now..up in scotland....nuffin to do with me!
Brenhden
Post by Brenhden »
There are a couple more DR650 on eBay that look good.
Brenhden
Post by Brenhden »
So Saturday I changed the oil and filter and looked at the leaking CCT gasket. Sunday I did the gasket but she wouldn't start, even jump start. Thought I'd buggered the timing chain.
Tonight I decided to unjam the choke cable and went to take the tank off only to find I must have turned the fuel off on Saturday. Bike started right up and runs sweet. Choke was a good fix too (thumbs)
HAMMERHEAD
Post by HAMMERHEAD »
Brenhden wrote:So Saturday I changed the oil and filter and looked at the leaking CCT gasket. Sunday I did the gasket but she wouldn't start, even jump start. Thought I'd buggered the timing chain.
Lol. Not on your own there buddy, I've done exactly the same, sure there are a few more on here have done also. Teehee.
PHILinFRANCE
Has thanked: 3467 times
Been thanked: 1823 times
Post by PHILinFRANCE »
:laugh: NOT THE FUEL BUT KICKED MY 250 TO DEATH BEFORE I SAW THE KILL SWITCH IN THE OFF POSITION :laugh:
SHarper
Has thanked: 427 times
Been thanked: 904 times
Post by SHarper »
Eyup readers of the DR thread, I'm coming on here and asking for the wisdom of the collective on a DR related matter.
A friend has bought a DR 250 and it doesn't run correctly. It starts and now ticks over but when you try to ride it, it bogs down, like there's a lack of fuel.
Someone has butchered the top of the airbox.
I took the carb apart, it had a 110 jet in it, so I did a bit of research and it looks like it should have a 135, but because of the airbox mod I put a 140 in it. The plug is a NGK CR9EK. It has a flat-slide Mikuni.
Does someone have manual for a 1996 (?) (M Reg import) DR 250 (don't know what the model designation is) that could tell me the correct plug, the correct jet size and what the fook is up with this fooking fooker of a machine that I never wanted anything to do with in the first place.
Brenhden
Post by Brenhden »
Hi SHarper,
I've got the Clymer manual at home for the DR350 and I think it covers the 250 too. I'll be home Wednesday and will take a look.
Bren
boboneleg
Has thanked: 2363 times
Been thanked: 1407 times
Post by boboneleg »
I've been looking through what information I have but it's quite difficult without knowing which model it is. Does it have the DOHC cam engine?
