what have you done to your bike today??
Re: what have you done to your the bike today??
Removed pannier rails, engine bars, satnav mount, spots etc., swapped handlebars back to original ready for pxing for a r1150gs adv.in a couple of weeks.
Added single seat conversion and KTM adventure bars then took it for a small try down a green lane ...suspension and tyres really not that suitable but it coped ...
Realised the mot ran out 5 weeks ago :huh:
Then:
Honda MB5, Honda MBX125, 350LC, RGV250, MTX125, GasGas JTX250, CM 644 DS, BMW R1100S, Beta Rev3 250, Beta Rev4T, Honda XL700V Transalp, BMW F800 GS, Kawasaki Super Sherpa
Now:
Montesa 4RT, Triumph Tiger 800, Beta Alp, Montesa 315
Now:
Removed all calipers. Checked pads. All okay. Cleaned everything up. Reassembled. Replaced brake fluid. Front brake tied back for the night. Never done this before. A lot easier than I thought it would be. Guess riding it tomorrow will show if ut really was that easy
Drained engine oil and removed oil filter. Will fit new filter and add oil tomorrow.
Finally got the 1953 Matchless G80, 500, on the road and out for a shake down ride. 78 miles of mainly country roads and the only fault was the throttle twist grip was a bit loose on the H/bars and needed the clamp screw tightening to fit.
I did try to go for a ride the night before and got as far as the local pub down the road when the clutch release stuck and I needed to give it a tweek and adjust to get going again.
Now it's on the road and going OK, the plan is to fit a V-Reg solid state regulator inside the old Lucas regulator box, LED bulbs front and rear, (I'll leave it at 6V). Replace the clutch and brake levers as the ones fitted give too long a pull on the cables. (7/8 inch pivot to cable end on AMC machines, most repro levers are 1" or 1,1/8". Tune up the motor as there is a flat spot mid range, should be just raising the needle a bit. A bit of paint touching up and an oil change in a few of hundred miles and that's it. Should be fine for another 60 plus years. (thumbs)
PS, Cables from JJ Cables supply top quality parts for classic bikes, far better than anything the club can supply and only a pound or two dearer.
Started the strip down for the rally rebuild to begin
R1100RT:
Changed oil,
Oil filter,
Air filter,
Spark Plugs,
Secured a couple of loose panels.
Cleaned a few rusty fasteners and replaced a few missing ones.
XT660R
Changed oil,
Oil filter,
Air filter,
Front tyre,
Front tube,
Replaced rear brake line,
Changed rear brake fluid,
Changed rear wheel bearings
Changed Cush drive bearing,
Replaced Rear wheel oil seals,
Took old tyre off... and didn't like the look of the tube.
To be continued...
Changed oil,
Oil filter,
Air filter,
Spark Plugs,
XT660R
Changed oil,
Oil filter,
Air filter,
Front tyre,
Front tube,
To be continued...
- Has thanked: 754 times
- Been thanked: 632 times
Rode my V-Strom DL1000 a short 70 mile run out today on sundrenched roads in bonnie Scotland, sublime.
Loving the newly fitted Tourance Next rear tyre, excellent grip with confidence.
Frank Zappa
Frank Zappa
