Burr fixing tool, genius.
- Has thanked: 570 times
- Been thanked: 894 times
Re: Burr fixing tool, genius.
i think its very good ...only problem is it only starts at m8 so limited use for a motorbike ..it obviusly works well ..things like exhaust header studs it coild well solve a problem
A clever fix for a problem that doesn't really exist? A bit like the cucumber cap.
A thread file does the job for me
Dave
- Has thanked: 19 times
- Been thanked: 18 times
B)
I use this type of thread restorer to chase damaged threads, sealy do this one at a reasonable price
https://www.google.co.uk/url?sa=t&sourc ... -LWhuf92tg
I got this works great ,always in my on bike tool kit.
Jon
Jon
in my game we need to cut bar and repair threads all day long
this tool will help speed things up a lot
People keep mentioning using thread chasers, die nuts etc....This tool isn't designed to replace those. Its a way of cleaning the end up so you can start a thread chaser or die to sort thread damage further down the bolt or stud. If the end of a thread is damaged then you cant start a die can you ?
It reminds me of better version of the spot welder electrode dressers I used to use.
Anybody who has had to thread bar stock will see the value of this tool.
I'm usually very easy to persuade to spend my money on toys but I'll stick to using a file thanks.
A 4" half round file will fit in any tool roll and do the same job wherever you are in the World (thumbs)
Well yes, but not at $65 :blink:nug800 wrote:People keep mentioning using thread chasers, die nuts etc....This tool isn't designed to replace those. Its a way of cleaning the end up so you can start a thread chaser or die to sort thread damage further down the bolt or stud. If the end of a thread is damaged then you cant start a die can you ?
