James May The Reassembler Honda 50
- Scott_rider
- Has thanked: 29 times
- Been thanked: 294 times
Re: James May The Reassembler Honda 50
£6895 for that Africa style monkey bike...wtf! :silly:
- Been thanked: 126 times
What a load of twaddle.I can understand people might like the monkey bike but it was clear it hadnt had any work done on it from when he took it apart.No powder coat,no new paintwork so what was the point of the show again!
- Has thanked: 95 times
- Been thanked: 448 times
Looked forward to some detail on the centrifugal(centripetal for the purists) clutch and the disengagement system when the gear lever is pressed--its a work of simplicity, reliability and Honda magic--but there was nothing on the engine! I've modified one of those clutches with my own bobweight design to give much more plate clamping force--but thats another (long) story--I even attempted to make a diesel out of one with a Yanmar injector and a third cam lobe with a cross mounted injector rocker--sort of worked but you can't make a diesel smaller than about 200cc--its a surface area to volume ratio thing, and a small engine loses too much heat on compression--and thats another (long) story!!
vRSG60 wrote:I recorded it, can I gather it's not worth watching.
Keep it safe you'll be glad you did as next to snooker it is surely one of the best cures for insomnia :laugh:
Had me in the.land of nod in minutes.
Watched 1 minute and then switched to car sos doing a mini cooper
good move i think
good move i think
- Been thanked: 1 time
I think you are probably a better candidate for hosting this programme.catcitrus wrote:Looked forward to some detail on the centrifugal(centripetal for the purists) clutch and the disengagement system when the gear lever is pressed--its a work of simplicity, reliability and Honda magic--but there was nothing on the engine! I've modified one of those clutches with my own bobweight design to give much more plate clamping force--but thats another (long) story--I even attempted to make a diesel out of one with a Yanmar injector and a third cam lobe with a cross mounted injector rocker--sort of worked but you can't make a diesel smaller than about 200cc--its a surface area to volume ratio thing, and a small engine loses too much heat on compression--and thats another (long) story!!
norty
- Paul_C
- Has thanked: 1012 times
- Been thanked: 1149 times
He covered the Centrifugal clutch when doing the lawnmower in series one.
Just along for the ride.
Did you not stay on Channel and watch the following fascinating program about model trains ? :whistle:
