help to solve a problem please
Re: help to solve a problem please
The simple solution is narrower bars, if you live with that.
You could get into some serious fabrication and manufacture some folding / adjstablebars. There are adustable bars out there but they are set and leave designs, you would need something that can be adusted on a daily basis without working loose.
- Been thanked: 126 times
Can you make a smaller set of bars to use whilst you move it from front to back with the other bars sat sideways across the yoke still connected with all cabling?
Through the front door, keep the bike in the house. Tell the wife its a compromise you have to make to find her the perfect property.
- Been thanked: 2 times
How wide do you need? If its only a couple of inches you need then Still saw an angled groove out the brick work and stick plastic corner protector in it to save your bar ends or build a cavity into the fence. If the house is right apart from that there will be a way (thumbs) even if there is drain pipes put brackets and sliding joints on them (thumbs)
Too many Cagiva Elefants, Gran Canyons and Ducatis!
Azzalin SP and various others.
We had to have the back wall of our garage knocked out and doors put in so we can get bikes through to the workshop
The right property for both of you is out there be patient. If it's such a pain to get bike out you will find you won't be bothered all to often.
