Came with my current bike but not needed.
Hand-made in USA.
Very nicely fabricated and welded, then lacquered from ~1.5mm sheet.
Suits a high-pipe bike (like most adventure bikes) where the pipe requires
one case to be narrower to look balanced.
Each cases weighs 5.1kg.
Feel much more solid than my old Touratech Zegas.
Similar to Bernd Tesch Expedition cases
The bevel on the lower outside edge minimises digging in
and stresses if you fall, while adding rigidity/strength.
The top open edge of the box is also carefully folded in to greatly
increase the rigidity and strength of the box.
Left: 27cm x 46 x 38 high, less bevel ~ 45L est
Right: 23-27cm x 46 x 38, less bevel ~ 41L est
No marks or deformation from being crashed or fallen on, but there are light scratches and marks from stickers and a shallow dent at the front panel of one case.
Rubber foam lid seals intact. Lids hinge forwards so as not to interfere with rear loads.
Neat, easy-to-use turn-lock hasps and 4 tie-down loops on each lid top for more stuff.
Cases rest on the lower rail of a flat rectangular rack loop and secure to the upper rail with two M8 wheel knobs each side.
My rack had threads; you can make or buy some Touratech-style 'L-swivel' mounts.
All depends what sort of rack you have.
One M8 fixture is a replacement T-knob (the original wheel knob was cracked)
A few T-knob spares included.
Also included: unused 2-litre Touratech fuel bottle with strap.
Solar panel with USB port and mini-USB cable.
Charges battery packs or direct to device.
Additional mystery gift also included.
More pix on ebay.
Cheapest way is to send as two separate Collect Plus parcels.
Or collect for free South London.
Please note: not around to send between Aug 27-31 but you can collect.
Below: not these panniers but similar
Alloy cases (41/45L) + fuel bottle + solar panel • £270 ~ London
Re: Alloy cases (41/45L) + fuel bottle + solar panel • £270 ~ London
Now £270 and de-stickered.
- s-l1600.jpg (191.27 KiB) Viewed 1466 times
Re: Alloy cases (41/45L) + fuel bottle + solar panel • £220 ~ London
Last call: £220 before I make them into a garden feature.
