Gear clearout
- PADDYTFIELD
- Has thanked: 10 times
- Been thanked: 2 times
Gear clearout
Hi
Having a clearout.
Almax chain 1.5 m 19 mm with Squire lock 2 keys,way too heavy to take touring 10.5kg ideal for securing battleship,been kept outside so a bit grubby.£40 SOLD
Primus eta spider gas stove set,you can get a kit to change it into petrol, very quick vgc £40
Tomtom Rider 450 powered cradle, security mount 2 keys,I upgraded from a rider 400 to the 450 and it was too much of a faff to swap all the wiring and Ram mounts around so I just popped it on the existing setup as a result all the new mounts are still sealed ,the new security lock only has 1 key instead of a flat and a round key,you now get a plastic knob to secure it.£40 SOLD
Tool tube never used £10
Garmin foretrex 401 wrist worn gps with extended wristbands vgc £35
Strobe .white,blue and infrared £25.
I’m in Scarborough, the Chain would be expensive to post,I’m happy to meet up and deliver within reason.
I seem to be having difficulty posting more than 3 photos,pm me if you want a look or can meet up.
Cheers Paddy
Having a clearout.
Cheers Paddy
- 7F5B77FF-0BEA-4204-8CF6-E38110BE44AA.jpeg (163.22 KiB) Viewed 4129 times
- 944551A9-834E-4C45-84E9-24E472AC2DD0.jpeg (232.46 KiB) Viewed 4129 times
- 1FD8FF76-4C32-4961-9F9B-0A0EFB4F8878.jpeg (186.67 KiB) Viewed 4129 times
- PADDYTFIELD
Re: Gear clearout
Hi
Thanks for that,just seen other posters have split their items over a few posts.
Paddytfield
Paddytfield
- Been thanked: 126 times
Re: Gear clearout
I will have the Almax if you don't mind posting Bud?
EDIT Sorry didn't read all the way to the bottom that said Parcel2Go should give a reasonable rate and you can usually just drop it in a nearby shop
https://www.parcel2go.com/
£7- £10 depending on which courier you select for 11Kg
- PADDYTFIELD
- PADDYTFIELD
Re: Gear clearout
Just to be as honest as possible the outer sleeve is knackered,because it’s covering a ruddy great chain...
And it looks like it’s been dragging around the floor:because it has...
That said,it would cost £189:99 for a shiny new one.
I assume your going to secure something and you’re not getting this to appear all Gangsta down the pub,in which case I think you’ll be very happy.
I’m at my Sons wedding on Friday so not free then,apparently I’m not allowed to touch anything oily on that day,if you’re a couple of hundred miles away I could split the difference and meet you.
Re: Gear clearout
I'm near Manchester so if you PM me payment details with say a tenner postage I will send it over and just post it when you get a chance [no rush]
- PADDYTFIELD
