Have a look at their shop. 1 metre to 3 mtres with or with out hooks. very well made and with a Uk breakage rating. Nothing to do with me but they are bloody good so spread the word and all that.Oop North John wrote:Having a senior moment hmy: but am I right in guessing that as there's no hook then you loop the straps around the bike / secure point in a loop? In which case is 1 metre long enough?Helicoptermanr22 wrote:Just bought some of these. made in Cornwall so gotta be good, have to say, really impressed..eBay item number:302083404582
Tie down straps
- Has thanked: 21 times
- Been thanked: 131 times
Re: Tie down straps
Re: Tie down straps
They can make up them up from 1 metre to 5m.... cam buckle version with hooks on if you need them.Oop North John wrote:Having a senior moment hmy: but am I right in guessing that as there's no hook then you loop the straps around the bike / secure point in a loop? In which case is 1 metre long enough?Helicoptermanr22 wrote:Just bought some of these. made in Cornwall so gotta be good, have to say, really impressed..eBay item number:302083404582
Business seller information
Big Cushion
Richard Harries
1 The Square,
Pentewan
St Austell
Cornwall
PL26 6DA
United Kingdom
Phone:01726 844938
Email:[email protected]
- Been thanked: 126 times
Re: Tie down straps
Ive seen these recommended in previous threads
http://www.handystraps.co.uk/categories ... n-blue/46/
- Been thanked: 1 time
Re: Tie down straps
If you buy 2m long ones, then cut them in two (best if the end with the cam buckle on it is about 30-40cm long), and sew a soft loop into the cut ends, this makes a set of tie downs that you can actually get some tension on unlike using them as a loop.
Put the cam buckle end on the bike, feed the buckle through the soft loop you have sewn onto this end, tie the other half off to the deck points/cables/trailer tie downs then feed the free end through the cam buckle and pull to tighten.
I get mine from Robert Harwood
- Has thanked: 154 times
- Been thanked: 199 times
Re: Tie down straps
Hidden away in the FAQ's is the statement that they'll tie the bike down while the owner is still present:92kk k100lt 193214 wrote: But the ferry company generally always does a tie down with their own, especially Brittany Ferries on the Pont Aven.
http://www.brittany-ferries.co.uk/faq/s ... cle-straps
So, if the bike falls over, who's insurance should pay out for any damage?
- Has thanked: 24 times
- Been thanked: 28 times
Re: Tie down straps
BMW ship their bikes with cam buckle ones. They are white and very stiff nylon staps and if you pop down to your local BMW dealer they may give you some instead of throwing them away.
I have some and they are tough as old boots.
Re: Tie down straps
I know some do not like cam buckles...
I have to say I did many many miles with them in days gone by, but the cheap and nasty ones usually being sold now are made of chinese monkey metal and simply fall apart. :unsure: I'll be interested in a review of the one from Cornwall.
Re: Tie down straps
Thats why I think you probably better off with end loops rather than hooks which can bounce loose and come of the tiedown points
