i know quite a few on here have sidi adv boots, i have a concern with the rate of wear on the toe area on both boots.
gear change has worn part way through, checked the bike and no rough areas even have taped them up and noticed this morning the right boot is showing signs of wear,
this carnt be right, anyone else have this problem
steve
Sidi Adv Boots
Re: Sidi Adv Boots
Not had any issue of wear, myself.
Pair I have. have done quite big distance over 6 years .
- Has thanked: 803 times
- Been thanked: 534 times
Re: Sidi Adv Boots
No problem with mine , the boots have a gear change pad on them , has yours worn through that ?
Re: Sidi Adv Boots
Hi Steve the boots have a pad on left and right boot from new , I only bought them last August so maybe pads on the later ones !!!ollydog wrote:hi bob, not worn through yet, did you get the pad made or off the peg, have you any details
steve
Re: Sidi Adv Boots
Hi, had mine 5 years now and many miles. They had gear lever pads from new. Had them resoled last year at nearly 100 quid but worth it. I look after them regularly waxing etc. Uppers still look good apart from rock scratches/cuts, also still waterproof. Brilliant boots, well worth the initial outlay. Nige.
Re: Sidi Adv Boots
Ha, just remembered, before I could buy such boots we used to put a section of inner tube rubber around the riding boots on the gear change side. This protected the leather uppers nicely from lever marks. Back in the day!
- gbags
- Has thanked: 1087 times
- Been thanked: 669 times
