Just bought some
https://www.aldi.co.uk/gt85-bike-mainte ... 8198125000
Aldi today GT85...£1.99
Re: Aldi today GT85...£1.99
GT 85 is a silicon spray, whereas I think the main constituent of WD40 is fish oil. They both lubricate but it depends what you are lubricating. Some plastics swell under contact with WD40. You should not use WD40 to lubricate cables with plastic inners. If you use WD40 to keep the water out of spark plug caps, it works great for a short while but makes the plastic swell to allow more water in over time.
On metal to metal joints I personally think WD40 is slightly better. It also seems better at freeing rusty bolts.
Both have cleaning uses but again it depends what you are cleaning. Black plastic components will benefit from GT85.
Cheers Jak
Cheers Jak
- Has thanked: 419 times
- Been thanked: 158 times
I USE gt85 ON MY DIRTBIKE CHAIN AS IT DRIES 'DRY' BUT LEAVES A SLIGHT FILM TO STOP RUST SPOTS APPEARING AND IVE JUST RUN OUT! SO A VERY TIMELY HEADS UP! tHANKS tINK
- Has thanked: 646 times
- Been thanked: 214 times
- Has thanked: 754 times
- Been thanked: 632 times
Just bought 5x tins from my local Aldi which should last me a while.
Thank you!
Peter
Thank you!
Peter
Frank Zappa
Frank Zappa
- Has thanked: 2280 times
Any advance on SIX tins
Other thing I like about the GT85 is it comes out at a higher pressure, makes clearing crud a bit easier.
it woulda been more but my old age pension is not due till the weekend ..
(but I can still bend and clean like fukkk .. )
