I've just bought an Africa Twin and it's the first time I've had a bike with tubes rather than tubeless tyres.
Previously I've carried tyre plugs and gas cannisters to repair punctures and thankfully never needed them.
What should I look at carrying to repair punctures on the Africa Twin tyres? Obviously a spare tube is a good start but what else in teh way of tyre levers etc?
Tube Tools?
- boboneleg
- Has thanked: 2363 times
- Been thanked: 1407 times
Re: Tube Tools?
Get the best tyre levers you can, Buzzetti are the best in my experience
one-legged adventurer
- OB1
- Has thanked: 746 times
- Been thanked: 342 times
Re: Tube Tools?
justrtw.com
justrtw.com
- Has thanked: 419 times
- Been thanked: 158 times
Re: Tube Tools?
I use three tyre levers and a 'bead buddy' it makes changes a lot easier, ive just bought a high volume hand pump as it fits under the seat and is just as good as those plug in electric ones and takes up far less room! a 21" spare tube as will be able to use it for both wheels. And a nifty trick i learnt was to use the side stand as a bead breaker (only works if you have a centre stand! bike on centre stand, wheel off and slid under side stand, rock bike towards you and voila! pop goes the bead) and a couple of spanners for the wheel nuts and chain adjustment and that's about it really. Anything else is way beyond my mechanical ability so it would be AA/RAC for anything else lol.....
- OB1
Re: Tube Tools?
Do you have a link to this or a brand and model? TIA
justrtw.com
justrtw.com
Re: Tube Tools?
hahahahahahahahaha... ok ok here you go from Halfords:
https://www.halfords.com/cycling/bike-m ... -hand-pump
- Has thanked: 52 times
- Been thanked: 156 times
Re: Tube Tools?
BTW, do practice changing the things at home first! Also, patching tubes can be a nightmare because the patches fail so often and some damage can't be patched, better carry a spare front wheel inner as well as patches.
Hand pumps are fine if you are Popeye. Get an electric pump.
Re: Tube Tools?
I think the higher psi one has lower volume Russ! the bloke in the shop reckons that one is the best for a motorcycle inner tube. Agreed it will take quite alot of pumping still, but as long as there is enough air to get you to a garage thats ok, and i also carry a couple of the air canisters. I haven't tried it out yet (hope i never have to really lol...)
